Disconnect error
For some reason if my wireless weather station loses connectivity the WD sends some pretty outrageous numbers to the web- temp 11829- wind 57 mph etc. Any way to make it send the last reading and continue to send that until the wireless weather station reconnects? WD itself displays the last good reading, but clientraw.txt has the high numbers.
WIN 10
WD V10.36s62
Weatherwise Solar Pro
what is the weather station type you have selected in WD?
Easy Weather/WH1080/81-PC/Zephyr or clones.
when the problem occurs, set WD to log the raw data (setup, advanced/misc)
then let me know what shows under view, debug info
Raw barometer 955.8
Raw indoor temp 29.6
Raw Outdoor hum =255
Data update 05:23:49 07/01/18
Indoor hum =66
Indoor temp =29.6
Outdoor hum =255
Outdoor temp =6553.5
Barometer =955.8
Wind speed = (km/h) 91.8 raw 255 255
Gust speed = (km/h) 91.8 raw 255 255
Wind direction =3105
Total rain =238.2
checking for email warning part 1
checking for email warning part 2, flag current temp 6553.5 threshold 50.0
Offset = 1552 N = 6
clientraw.txt (829 Bytes)
OK, what I need to do is check for those 255 (i.e NULL) values and make sure to ignore data like that
I will do that and let you know
try a new .zip update of WD
Awesome thanks I’ll let you know.
k
well showing -148 while connected-
www.plewfarm.com/weather
clientraw.txt (799 Bytes)
do you mean that its not picking up correctly normal data now ?
yes it is not -148
that is odd
if you could post here what shows under view, debug info
(i.e the raw data etc)
when you have set to log the raw data, under setup, advanced/misc
Raw barometer 957.5
Raw indoor temp 28.2
Raw Outdoor hum =98
Data update 07:32:41 07/02/18
Indoor hum =80
Indoor temp =28.2
Outdoor hum =98
Outdoor temp =22.6
Barometer =957.5
Wind speed = (km/h) 2.5 raw 7 10
Gust speed = (km/h) 3.6 raw 10 0
Wind direction =45
Total rain =238.2
07:33:01 uploading C:\wdisplay\alldayvideo\tensecondvideo.mp4
Offset = 2384 N = 9
Raw 30 0
Raw 80 1
Raw 25 2
Raw 1 3
Raw 99 4
Raw 222 5
Raw 0 6
Raw 103 7
Raw 37 8
Raw 7 9
Raw 10 10
Raw 0 11
Raw 1 12
Raw 26 13
Raw 3 14
Raw 0 15
Raw 16 16
Raw 80 17
Raw 26 18
Raw 1 19
Raw 98 20
Raw 226 21
Raw 0 22
Raw 103 23
Raw 37 24
Raw 3 25
Raw 7 26
Raw 0 27
Raw 2 28
Raw 26 29
Raw 3 30
Raw 0 31
Raw 0 32
Raw barometer 957.5
Raw Outdoor hum =98
Data update 07:33:03 07/02/18
Indoor hum =80
Indoor temp =28.2
Outdoor hum =98
Outdoor temp =22.6
Barometer =957.5
Wind speed = (km/h) 1.1 raw 3 7
Gust speed = (km/h) 2.5 raw 7 0
Wind direction =45
Total rain =238.2
Offset = 2384 N = 9
Raw 30 0
Raw 80 1
Raw 25 2
Raw 1 3
Raw 99 4
Raw 222 5
Raw 0 6
Raw 103 7
Raw 37 8
Raw 7 9
Raw 10 10
Raw 0 11
Raw 1 12
Raw 26 13
Raw 3 14
Raw 0 15
Raw 16 16
Raw 80 17
Raw 26 18
Raw 1 19
Raw 98 20
Raw 226 21
Raw 0 22
Raw 103 23
Raw 37 24
Raw 3 25
Raw 7 26
Raw 0 27
Raw 2 28
Raw 26 29
Raw 3 30
Raw 0 31
Raw 0 32
Raw barometer 957.5
Raw Outdoor hum =98
Data update 07:33:25 07/02/18
Indoor hum =80
Indoor temp =28.2
Outdoor hum =98
Outdoor temp =22.6
Barometer =957.5
Wind direction =45
Total rain =238.2
Offset = 2384 N = 9
Raw 30 0
Raw 80 1
Raw 25 2
Raw 1 3
Raw 99 4
Raw 222 5
Raw 0 6
Raw 103 7
Raw 37 8
Raw 7 9
Raw 10 10
Raw 0 11
Raw 1 12
Raw 26 13
Raw 3 14
Raw 0 15
Raw 17 16
Raw 80 17
Raw 26 18
Raw 1 19
Raw 97 20
Raw 226 21
Raw 0 22
Raw 103 23
Raw 37 24
Raw 0 25
Raw 3 26
Raw 0 27
Raw 8 28
Raw 26 29
Raw 3 30
Raw 0 31
Raw 0 32
Raw barometer 957.5
Raw Outdoor hum =97
Data update 07:33:47 07/02/18
Indoor hum =80
Indoor temp =28.2
Outdoor hum =97
Outdoor temp =22.6
Barometer =957.5
Wind speed = (km/h) 0.0 raw 0 3
Gust speed = (km/h) 1.1 raw 3 0
Wind direction =180
Total rain =238.2
that shows the data is being read in correctly
where are you seeing -148 exactly?
Take a look at my webpage
https://www.plewfarm.com/weather
Interestingly the high and low are correct.
you can look at the clientraw.txt there as well
check what you have set as the max/min temp limits in WD (control panel, offsets-> limits)
see attachment
the best thing is to .zip and email me your settings files (see the FAQ for how)
is the incorrect temperature also showing in WD?
Will do. No it’s fine in WD just the web.
can you post a screen shot of your WD main screen?
