Just a thought but maybe a useful feature for a lot of us...
Weather Display exports a csv file every minute that could be used by VWS in station-less mode so people could run VWS and WD at the same time without the need for VirtualVP?
I have used VWS as long as WD and still use Image salsa that uses VWS. Also, due to VirtualVP being forgotten, VWS disconnects for me daily from VirtualVP. that is the reason to try to find a solution to syop using VirtualVP. I know some people may say why would WD developer even consider this? don't know why, can't answer that
. But imagine a "publication" option in the control panel that one could easily enable this?
I was able to create a file with current WD tags but hit a road block with how some data is formatted by WD and is not usable in VWS. For example, the month of June is "6" in VWS and "06" in WD. see the two examples below...
csv file created with WD tags:
1.01,2018
,06,10,14,45,
01,7.7,7.0,296,28,13,84.3,100.0,29.667,2.19,0.00,0.00,0,0,0,0,0,0,0,0.26,0,881,100.0,0,95,40,0.000,
+2.4,0,-0.023,0,0,0,0.00,2.19
VWS generated data.csv:
1.01,2018,
6,10,14,44,
0,6,7,269,28,13,84,100,29.67,2.19,0.00,0.00,0,0,0,0,0,0,0,0.26,0,881,100,82,95,40,0.00,
2,1,-0.02,0,0,0,0.00,1.31
