Running version 10.37S Build 72, On Windows 10
The web cam capture overlay text will not retain the font size after restarting the web cam capture program (ver. 10.05).
I have it set to size 18 and it will default back to 8 every time.
This has been a small long time bug that I know one other person is dealing with also.
After changing it back to size 18 I do click on save. Also on the “set the text colour/font” I have it set to 18, both have had no effect on getting it to stick to the font size of 18.
try the more update to date version maybe
http://www.weather-display.com/downloadfiles/wdwebcamcapture.zip
but also you can select the actual font and then set the actual font size with that font selection
Tried out the newest version. Its worst for me for some reason.
The Overlay enabled box will not stay ticked for.
Managed to find a fix for the bug (or for my error) in the older version.
Here is what worked.
Under overlay turn off/unticked all the boxes under Weather Label.
Cleared out anything I had in the “custom tags/text to include” that is in the Weather Label box.
(I had been using that for my custom text and not the area in the upper left corner of the overlay tab)
At the upper left hand side of the overlay tab setup the text needed in the Text/custom tags overlay and used number 1 for that setup.
Set up the text size only under “Set the test colour/fount”
This works now and it saves the settings after a restart.
