Custom Web Page Location
Do I have to put my custom web pages in the webfiles folder for conversion to the root directory of the site? I am in the process of changing from VWS to WD and have changed all the VWS tags on the local weather page to WD. There are links to images and folders that will break if I build the file in the webfiles folder and convert and upload it to the root. I have changed the location of ‘webfiles’ from the WD directory to the local server directory (C:\Apache24\htdocs\webfiles) which is mirrored on the Internet server.
http:/www.railroadflat.org is the home page and I would like a weather page and a few other pages mostly made up of images WD generates.
http://www.railroadflat.org/wxlocal.html is the page I’m working on and trying to figure out how to place and convert it (to weather.htm).
mike
you can select the location where WD stores the webfiles
under control panel, webfiles/web page setup
(click to select web files directory)
That was the hint I needed. I thought the folder needed to be called “webfiles” but knew I could change where it went.
This is the exact same structure I used with VWS.
mike
interesting place where you live
https://en.wikipedia.org/wiki/Rail_Road_Flat,_California
I did go on a, agricultural field trip in that area when I was studying at UC Davis many years ago 8O
