I am using the most recent version of WD, on a windows 10 PC. I set up WD to update my meteotemplate under Publication>Meteotemplate. When I click the test/update button it updates correctly, however it wont update after that. I have the slider “on” and the main internet “on” - I have tested it with all the update intervals from 3 sec to 5 mins with no luck. I also downloaded a fresh install of WD onto a different PC and tried it with that and still having the same issue. As it updates correctly when I push the button but not on its own Im thinking something might be broke with WD- am I missing anything ? Anyone have any Ideas?
check to make sure that you have the main internet switch on
(I did reply to your email about this)
So im an ass- the issue wasn’t with WD OR Meteotemplate, it was with my hosting provider. I have another subdomain, which was done with word press- there is a known issue where wordpress can interfere with api’s and cron jobs. Moved to new host and everything is fine
