Rainfall Errors
Brian
Brian
having problems with rainfall totals as shown in attached screens… part 1
Rainfall total to midnight was 22.4 mm rest to 0.0 at 1 min past then accumulated to 6.4 mm @ 08:59. Then 09:00 shows 0.0
followed by 6.4 @ 09:01… and @ 09:02 a 6.4 mm figure appears in Rain Min column [?]
Brian
todays graph of rainfall @ 09:14
do you have set to use the aus 9am reset time?
also what version/build of WD?
do you also maybe have set to use the console rain totals?
Brian
WD version is 10.37S72
Time reset is Aus 09:00 and NOT set to use Davis totals.
Have installed anemometer and tranfered program / data to a dedicated mini computer with current version of windows 10 [April update ], 4Gb Ram 120Gb ssd Hd
if you could .zip and email me your settings files, I will do some testing/checking here
Which files do you want??
…or screen shots .??
See this FAQ.
files sent as requested
I have tested here with your settings
but I can not reproduce the problem, when checking the logfile, 52018lg.txt
(what shows in that?)
Brain
Files sent by email
cheers
