My Weather Display will not post to Twitter automatically anymore. I has been down for several months. Nothing I do seems to resolve the issue. :roll:
what version of WD?
(make sure you have a recent version)
try revoking it from your twitter account (the app)
and delete the twitter.ini settings file from where WD is installed
then try doing a test send from WD and then re login/sign up
Did all that. Still won’t work. Will only post if I do it manually. Tried shorting the text and posting without image, still no avail.
ah
so it does work , but not auto
do you have the main internet switch on in the main connections setup?
do you have times set to send in the twitter setup, and the switch on there?
try setting the times different to other times you have set things to send too
OK got it to work. Thanks! I keep forgetting about that. I just assume if you can trigger it manually, it me be connected OK.
It still won’t forward my tweets to Facebook. That used to work great. It will only forward if I don’t include an image. I know someone said using twitter to post to Facebook was cheating, but they offer the app. If they didn’t want you doing this why would they offer the option?
