Author Topic: Humidity graph not shown  (Read 1212 times)
Online Asperitas
  • Android 7.0
  • Chrome 68.0.3430.2
Re: Humidity graph not shown
« Reply #15 on: May 21, 2018, 04:57:46 AM »
I did that, but still no graph and rate unfortunately.
Online Asperitas
  • Android 7.0
« Reply #16 on: May 21, 2018, 06:24:43 AM »
When i set all values in the dataposition fields to 1 as a test, its still getting the right data.
And when i start WeatherD.exe i see the mainscreen humidity graph is present, but in whole numbers, no decimal....
Offline bitsostring
  • Oregon Scientific WMR200
  • Edinburgh, UK
  • Win NT 10.0
  • Mozilla compatible
    • Home Weather Station
« Reply #17 on: May 21, 2018, 09:25:35 AM »
Executive is WeatherDisplay.exe, not WeatherD.exe.
It's meant to be fun. . .
Online Asperitas
  • Android 7.0
« Reply #18 on: May 21, 2018, 09:32:50 AM »
Yes i know, but it looks like the weatherdisplay.exe version gets its humidity graph data from somewhere else...
Offline niko
  • syzygy
  • Global Moderator
  • Northern California, U.S.A.
  • Win 7/Srvr 2008R2
  • Chrome 66.0.3359.181
« Reply #19 on: May 21, 2018, 01:55:08 PM »
WeatherD.exe is an old version of WD, do not run it. The name of the program changed to weatherdisplay.exe some time ago.
Online Asperitas
  • Android 7.0
  • Chrome 59.0.3071.125
« Reply #20 on: May 21, 2018, 02:03:08 PM »
Hi Niko,
Yes i know, but the time weatherdisplay.exe run for some hours without the humidity graphed, and then started WeatherD.exe, the humidity graph was shown ( in non decimal values) in the mainscreen graph in WeatherD.exe for the period weatherdisplay.exe has run......
Just as a test. :D
So that makes me think in weatherdisplay.exe the humidity data is coming from somewhere else.
Other weatherdata is shown immediately, with rate to...
At the moment, the humidity graph (in weatherdisplay.exe) is stuck at 60%, same with the rate, is stuck at zero,  while the actual humidity is in the low 40 and working fine/fluctuating.
See screenshot below:
« Last Edit: May 21, 2018, 02:14:12 PM by Asperitas »
Online Asperitas
  • Android 7.0
« Reply #21 on: May 21, 2018, 02:21:59 PM »
...and a screenshot from WeatherD.exe from the same period.
Which shows the humidity graph ok.
It looks like the graph lines are more sharp also... ?
« Last Edit: May 21, 2018, 02:37:32 PM by Asperitas »
Online Asperitas
  • Android 7.0
« Reply #22 on: May 21, 2018, 04:28:44 PM »
Fixed.
But what annoys me is i dont know what i changed/what caused it... :oops: i hate that... :(
What is the best way to save all the settings as they are right now?
Thanks very much for the help and reactions, much appreciated  :D
« Last Edit: May 21, 2018, 05:17:00 PM by Asperitas »
  • Davis VP2
  • New Zealand
  • Win NT 10.0
  • Chrome 66.0.3359.139
    • Weather Display
« Reply #23 on: May 21, 2018, 07:13:44 PM »
you can set WD to do auto backups of your settings/data:
under control panel,data back up
(the wdisplay.ini and wdisplayftp.reg settings files are the important ones)
Online Asperitas
  • Android 7.0
« Reply #24 on: May 21, 2018, 07:27:46 PM »
Thank you so much👍
Online Asperitas
  • Android 7.0
« Reply #25 on: May 22, 2018, 05:59:56 PM »
Very happy WD user :D
Online Asperitas
  • Android 7.0
« Reply #26 on: August 05, 2018, 06:43:46 PM »
Unfortunately the humidity graph and rate isnt working after updating WD.
The rate is showing zero and the graph flatline since running after update.
I forgot to wait after the update was running untill the message came to uncheck the option to ask permission to use cronwu or something.
So as soon as i unchecked that option, the data was ok, except the humidity graph and rate on the mainscreen.
The current condition and realtime graph is showing humidity just fine.
Campbell Scientific datalogger in use.
Ive restarted WD and converted log file to datafiles in the action menu and recreated last 31 days, but no difference unfortunately.
Theres nothing shown in program event log and humidity is being logged in log file.
Probably i can do something more to get it working again.
Thanks in advance. :D
« Last Edit: August 05, 2018, 07:08:38 PM by Asperitas »
Online Asperitas
  • Android 7.0
« Reply #27 on: August 06, 2018, 07:25:58 AM »
For some reason the hum graph and rate started to work just before 4 tonight.
Im curious as to why it started again after hours of flatline. I didnt change a setting.
Maybe i have something setup wrong?
Could be because im not that an expert on pc :oops:
With kind regards.
  • Davis VP2
  • New Zealand
  • Win NT 10.0
  • Chrome 67.0.3396.99
    • Weather Display
« Reply #28 on: August 07, 2018, 06:35:03 PM »
so you say not shown
you are actualling meaning
its showng
but its flat lining
i.e not getting new updates
which could be because the raw data is out of range
you would need to look at the actual raw data, when it is flat linning
Online Asperitas
  • Android 7.0
  • Chrome 68.0.3440.85
« Reply #29 on: August 07, 2018, 07:06:27 PM »
Yes youre right.
Is there a way to get it working again after i miss hum data?
For example: when for what reason WD stoppen collecting data for some time, the humidity graph and rate seem to not get data after WD started again, while all the other weather data are collecting immediately after WD started again, even if WD hasnt run for hours.
