My forecasts haven’t been updating for a while now. So I did some searching here today and ended up updating my advforecast2 script. I did add my zone and printable link.
Now pretty much none of my page will load and it shows the error
" Parse error: syntax error, unexpected ‘’ (T_ENCAPSED_AND_WHITESPACE), expecting identifier (T_STRING) or variable (T_VARIABLE) or number (T_NUM_STRING) in /home/content/69/6842969/html/weather/advforecast2.php on line 152 "
Line 152 is " if (isset($SITE[‘NWSforecasts’])) {$NWSforecasts = $SITE[‘NWSforecasts’]; } " and I just can’t figure out what the problem is.
$SITE['NWSforecasts'] = array( // for the advforecast2.php V3.xx version script
// use "Zone|Location|Point-printableURL", as entries .. first one will be the default forecast.
"NCZ032|Hertford|https://forecast.weather.gov/MapClick.php?zoneid=NCZ032&FcstType=text&TextType=2",
and the latter should be
"NCZ032|Hertford|https://forecast.weather.gov/MapClick.php?lat=36.1893&lon=-76.4657&unit=0&lg=english&FcstType=text&TextType=2",
You’ve likely made changes to advforecast2.php (which aren’t needed when you use it in the Saratoga template), and you’ve left off a ; or ’ or " from a previous statement. I’d suggest you just download a fresh copy of advforecast2.php (either version as you like) and replace your copy after changing the Settings.php as shown above. advforecast2.php automatically gets the required customization from $SITE variables in Settings.php, so you never need to configure it inside the script itself.
Thank You so much Ken, those were the problems. I will certainly get on updating the remainder of the scripts in the very near future, but not being one that writes much if any php code it can get a little overwhelming sometimes.
Again…many Thanks
