I’m not sure if this is a bug. I have not had any success getting the header to save in the 5 day forecast, maybe I’m not doing it correctly.
It is set until I have to restart or reboot, then it’s gone.
I also have the same problem with the camera webcam capture, I set the frame rate, but after shutdown or reboot it’s back to default.
Here is the screen shot for the 5 day forecast setting I’m using.
I don’t have any way I’m aware of to set the webcam driver software for frame rate. They do provide an interface but it is only image quality not size or frame rates.
It’s a Logitech HD Webcam C310.
I tried something different with the heading, apparently it didn’t like using the space bar for trying to center it.
Using underscore instead, it is being saved correctly. If I knew how to get rid of the date and time stamp at the left side I wouldn’t have to do that, as it is already automatically included in the header.
