Author Topic: Restarted and Cannot Get WD to Read Data  (Read 752 times)
Offline hcorrin
  • Ballaugh Isle of Man GB
  • Win NT 10.0
  • Mozilla compatible
    • Ballaugh Weather
Re: Restarted and Cannot Get WD to Read Data
« Reply #15 on: May 13, 2018, 09:03:36 PM »
I was about to ask if you has restarted due to an update and yes that may have caused the problem.
suggest you try a power down for 30 seconds then when computer up and running check the device manager again and if still no go try Niko's link for driver
Offline daughn
  • Madison, Alabama, USA 34:43:08N, 86:46:30W - Elev: 755 ft.
  • Win NT 10.0
  • Chrome 66.0.3359.170
« Reply #16 on: May 13, 2018, 10:39:54 PM »
hcorrin, did as you suggested with exactly the same results - cannot install the driver.  What now?
« Last Edit: May 14, 2018, 02:57:07 AM by daughn »
Daughn
Using Davis Vantage Pro2
CWOP:  CW3063
WeatherUnderground:  KALMADIS101
  • Davis VP2
  • New Zealand
  • Win NT 10.0
  • Chrome 66.0.3359.139
    • Weather Display
« Reply #17 on: May 14, 2018, 01:12:38 AM »
try unticking the setting in WD shown in the attached screen shot
and then restart WD
« Last Edit: May 14, 2018, 01:33:06 AM by Weather Display »
Offline daughn
  • Win NT 10.0
« Reply #18 on: May 14, 2018, 03:02:17 AM »
Did the unticking, but no improvements.  See attached.
« Last Edit: May 14, 2018, 03:31:59 AM by daughn »
Daughn
CWOP:  CW3063
Offline daughn
  • Win NT 10.0
« Reply #19 on: May 14, 2018, 03:29:15 AM »
The CP210x driver is not found in the device manager anymore.  It was earlier.  When I try to install, it fails.
Daughn
CWOP:  CW3063
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #20 on: May 14, 2018, 03:51:42 AM »
have you tried unplugging the re plugging back in the usb connection to the pc?
I assume weatherlink does not work either?
seems like a windows driver issue
Offline daughn
  • Win NT 10.0
« Reply #21 on: May 14, 2018, 11:58:45 AM »
I was trying several things and got a different Silicon Labs driver to work.  WD has been working ok last night.  COM11 is being used rather than the previous COM3.  Note that I tried to use the Windows 10 Universal driver but that is the one that did not work.  Finally, I used the one shown on the Download for Windows 7/8/8.1/10 (v6.7.5).  That one worked.  Should I be ok?  WD is now working correctly for about 10 hours.
Brian, should I tick the "Use this pressure for WD baro reading"?  You asked me to untick it earlier.
« Last Edit: May 14, 2018, 01:26:46 PM by daughn »
Daughn
CWOP:  CW3063
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #22 on: May 14, 2018, 06:20:48 PM »
you can re tick that
(only really needed though if you live at high altitude)
Offline daughn
  • Win NT 10.0
« Reply #23 on: May 14, 2018, 07:46:59 PM »
Thank you everybody that helped me!
Daughn
CWOP:  CW3063
