consolewd for raspberry pi - date problem
in consolewdfiles for raspberry pi 1 i get this message “25:27:00” is not a valid time.
When I check current time in terminal i get the right time. (пн май 7 01:27:00 EEST 2018) . In config.txt i use timezone=3 for 3 hours ahead UTC.
in 52018lg.txt is recorded:
6 5 2018 25 27 18.3 71 12.9 1013.2 1.0 1.7 255 0.0 0.0 0.0 0.0 18.3
do you mean you see that as an error message in the terminal window where consolewd is running?
its not very clear
Yes, I see that where consolewd is running, in terminal:
Station type raw=59<
Station type =59
Weather station type is an Irox
meteobridge user= <
meteobridge ip= 192.168.0.1<
meteobridge pass= <
Davis com method d
OWW file location= ←
program location= /home/weather/hdd/consolewdfiles32/<-
Davis VP IP data logger port= 22222<
Davis VP IP data logger IP= 192.168.2.3<-
Station name =mm32
Daily rain startup= 0.0
start up month rain found=0.0<-
Monthly rain startup= 0.0
Yearly rain startup= 0.0
wunderground username =
wunderground password =
wunderground utc =-5
time zone adjust =3
Dir offset= 0
Barooffset= 0.0
Comport is USB to serial
Davis com method d
Yes Revb Davis VP
Davis rain gauge .01 inch
mysql username =
mysql server =
mysql databasename =
mysql tablename =
Will do mysql metric
mysql time interval = 300
cwop station id =
cwop call sign = -1 // -1 is default (you do not have a Ham call si
cwop latitude=
cwop longitude=
FTP server = =166
FTP username =
FTP port = 21
FTPremote dir =
Will do ftp passive
remote file =
FTP time interval = 60
wu =Y
Will save logfile
logfile metric
Will create custom file
Custom file name = testtags.php
Custom file name 2=
Custom file name 3=
Custom file name 4=
Custom file name 5=
Tag units in celsius
wind units = m/s
baro metric= Y
rain metric= Y
Will run cron files
will update custom log
Custom log out = customlogout.txt
temp offset raw = <
hum offset raw =<
wmr300 channel =1
Modified rain gauge= .28<
WOW id=<-
WOW pass=<-
PWS id=<-
PWS pass=<-
windfinder id=<-
windfinder pass=<-
meteotemplatepass=<-
meteotemplateurl=<-
univeral update rate 2
utc hour=22
local hour=25
Weather Display vers WD_console_17.3
If use this program,then please consider sending a PayPal donation to [email protected] (Brian Hamilton)
to help with costs, and support, thanks!
www.weather-display.com
Irox opened OK
irox write 5
irox read -1
irox read -1
irox read 34
Raw irox baro 1013.1
irox Data OK
Current data 22:25:16: Temperature= 18.1 Windspeed =0.8 Gustspeed =0.4 Direction =270 Humidity=73 Barometer=1013.1 Daily Rain=0.0 Rain Rate 0.0mm/min
“25:25:00” is not a valid time
irox read -1
irox read -1
irox read -1
logfile1.txt (2.11 KB)
An here is part of 52018lg.txt
6 5 2018 26 45 18.3 73 13.4 1012.8 3.2 5.9 355 0.0 0.0 0.0 0.0 18.3
6 5 2018 26 46 18.3 73 13.3 1012.8 3.3 4.0 339 0.0 0.0 0.0 0.0 18.2
6 5 2018 26 47 18.2 73 13.3 1012.9 3.4 4.0 318 0.0 0.0 0.0 0.0 18.2
6 5 2018 26 48 18.2 73 13.3 1012.9 3.3 3.7 336 0.0 0.0 0.0 0.0 18.3
6 5 2018 26 49 18.3 73 13.4 1012.9 3.2 3.7 358 0.0 0.0 0.0 0.0 18.3
6 5 2018 26 50 18.3 73 13.4 1012.9 3.2 2.6 340 0.0 0.0 0.0 0.0 18.3
6 5 2018 26 51 18.3 73 13.4 1012.9 3.1 2.6 306 0.0 0.0 0.0 0.0 18.3
6 5 2018 26 52 18.3 73 13.4 1012.9 3.0 2.6 320 0.0 0.0 0.0 0.0 18.3
6 5 2018 26 53 18.3 73 13.4 1012.9 3.0 2.6 9 0.0 0.0 0.0 0.0 18.3
6 5 2018 26 54 18.3 73 13.4 1012.9 2.9 4.0 14 0.0 0.0 0.0 0.0 18.3
6 5 2018 26 55 18.3 74 13.6 1012.9 2.8 4.0 4 0.0 0.0 0.0 0.0 18.3
6 5 2018 26 56 18.3 74 13.6 1012.9 2.7 4.0 0 0.0 0.0 0.0 0.0 18.3
6 5 2018 26 57 18.3 74 13.6 1012.9 2.7 4.0 0 0.0 0.0 0.0 0.0 18.3
6 5 2018 26 58 18.3 74 13.6 1012.9 2.7 3.5 10 0.0 0.0 0.0 0.0 18.3
6 5 2018 26 59 18.3 74 13.6 1012.9 2.7 3.5 20 0.0 0.0 0.0 0.0 18.3
7 5 2018 3 0 18.3 74 13.5 1012.9 2.8 4.3 350 0.0 0.0 0.0 0.0 18.2
7 5 2018 3 1 18.2 75 13.7 1012.9 2.9 4.3 319 0.0 0.0 0.0 0.0 18.2
7 5 2018 3 2 18.2 75 13.7 1012.9 3.1 5.9 303 0.9 0.9 0.9 0.9 18.3
7 5 2018 3 3 18.3 75 13.8 1012.9 3.3 5.9 293 0.0 0.9 0.9 0.9 18.1
7 5 2018 3 4 18.2 75 13.7 1012.9 3.4 5.9 299 0.0 0.9 0.9 0.9 18.1
7 5 2018 3 5 18.1 75 13.6 1012.9 3.4 5.9 311 0.0 0.9 0.9 0.9 18.1
7 5 2018 3 6 18.1 75 13.6 1013.0 3.5 4.3 307 0.2 1.1 1.1 1.1 18.0
7 5 2018 3 7 18.0 76 13.7 1013.0 3.5 4.3 296 0.0 1.1 1.1 1.1 18.0
7 5 2018 3 8 18.0 76 13.7 1013.0 3.5 3.7 284 0.0 1.1 1.1 1.1 17.9
7 5 2018 3 9 17.9 76 13.6 1013.0 3.5 3.7 274 0.0 1.1 1.1 1.1 17.9
7 5 2018 3 10 17.9 76 13.6 1013.0 3.5 5.0 261 0.0 1.1 1.1 1.1 17.8
7 5 2018 3 11 17.8 77 13.7 1013.0 3.6 5.0 251 0.0 1.1 1.1 1.1 17.8
7 5 2018 3 12 17.8 77 13.8 1013.0 3.6 5.0 230 0.0 1.1 1.1 1.1 17.9
Ok, I solved the problem. It was localtime problem. :oops: :banghead:
What I did?
I used the tzselect command and made corrections.
Everything is alright now.
Station type =59
meteobridge user= <
meteobridge pass= <
Davis com method d
Station name =mm
Dir offset= 0
Barooffset= 0.0
Davis com method d
No Revb Davis VP
mysql username =
mysql server =
mysql tablename =
cwop station id =
cwop latitude=
cwop longitude=
FTP server = =166
FTP username =
FTP port = 21
FTPremote dir =
Will do ftp passive
remote file =
wu =Y
Will save logfile
logfile metric
Custom file name 2=
Custom file name 3=
Custom file name 4=
Custom file name 5=
wind units = m/s
baro metric= Y
rain metric= Y
Will run cron files
temp offset raw = <
hum offset raw =<
wmr300 channel =1
WOW id=<-
WOW pass=<-
PWS id=<-
PWS pass=<-
windfinder id=<-
windfinder pass=<-
meteotemplateurl=<-
utc hour=6
local hour=9
Irox opened OK
irox write 5
irox read -1
irox read -1
irox read 34
Raw irox baro 1013.3
irox Data OK
Current data 09:52:29: Temperature= 16.4 Windspeed =0.9 Gustspeed =1.3 Direction =202 Humidity=85 Barometer=1013.3 Daily Rain=0.0 Rain Rate 0.0mm/min
irox read -1
irox read -1
logfile2.txt (2.05 KB)
