@ BMX
I think your issue is more a driver issue
try updating to the latest silicon labs driver available
Thanks ever so much, didnt think to look in there.
I have just done this again now without issues this time, i noticed in the history that SL updated the drivers during May, looks like they have fixed what ever issues i had, thanks Brian, PS, i tried updating via the device manage but it failed with regards to an inf file, so i had to do it manually, downloading from SL
2 Days running and it crashes, well, not so much crashes, but it stops all data upload, wd is still getting data from the davis, but i cannot view any icons on the View screen but i can click the buttons, the wind dial disappears from the main screen, i cannot however close WD, not even from the task manager, this was why i resorted to just rebooting WD and it only ever happens during the night, WD only used 270mb out of 8gb and it only started after the spring update.
Memory test results: No errors detected
Error log
Above error or program log occured at :04 55 00 15/06/2018
error with house keeping Access violation at address 0088A850 in module 'WeatherDisplay.exe'. Write of address 00000000
Above error or program log occured at :22 01 10 15/06/2018
error with do timer 1 via units Thread creation error: Not enough memory resources are available to process this command
Above error or program log occured at :22 02 00 15/06/2018
Above error or program log occured at :22 03 00 15/06/2018
Above error or program log occured at :22 04 00 15/06/2018
Above error or program log occured at :22 05 00 15/06/2018
Above error or program log occured at :22 10 00 15/06/2018
Above error or program log occured at :22 10 01 15/06/2018
Above error or program log occured at :22 11 00 15/06/2018
Above error or program log occured at :22 12 00 15/06/2018
Above error or program log occured at :22 13 00 15/06/2018
some good clues there
try build 73:
Thank you, i will let you know, normally happens after 2 nights if it going to happen
I have not forgot to let you know, what i did was forget to turn off the auto reboot, its up to 66500 data count @81mb used, it would normally hang or whatever it does tonight, being the 2nd night, but i will give it another couple of nights if its ok tonight, then let you know.
I think I have fixed it, hopefully
strange that it was OK until a change in windows version
Ha ha, ya not gonna believe this, just got back in and WD had closed itself and the error log shows all this, i cant believe it after my post this morning, talk about tempting fate 8O
error with house keeping Access violation at address 0088A850 in module 'weatherdisplay.exe'. Write of address 00000000
Above error or program log occured at :06 06 09 19/06/2018
error with speech click Not enough memory resources are available to complete this operation
Above error or program log occured at :06 10 00 19/06/2018
Above error or program log occured at :06 10 01 19/06/2018
Above error or program log occured at :06 15 00 19/06/2018
error with monthtodate graph Out of memory
Above error or program log occured at :06 18 05 19/06/2018
Above error or program log occured at :06 20 01 19/06/2018
Above error or program log occured at :06 25 00 19/06/2018
Above error or program log occured at :06 30 01 19/06/2018
Above error or program log occured at :06 33 06 19/06/2018
Above error or program log occured at :06 35 02 19/06/2018
Above error or program log occured at :06 40 03 19/06/2018
Above error or program log occured at :06 45 01 19/06/2018
Above error or program log occured at :06 48 04 19/06/2018
Above error or program log occured at :06 50 01 19/06/2018
Above error or program log occured at :06 55 01 19/06/2018
Above error or program log occured at :07 00 01 19/06/2018
Above error or program log occured at :07 03 06 19/06/2018
Above error or program log occured at :07 05 01 19/06/2018
Above error or program log occured at :07 10 01 19/06/2018
Above error or program log occured at :07 15 01 19/06/2018
Above error or program log occured at :07 18 04 19/06/2018
Above error or program log occured at :07 20 01 19/06/2018
Above error or program log occured at :07 25 01 19/06/2018
Above error or program log occured at :07 26 32 19/06/2018
Out of memory
Above error or program log occured at :07 30 01 19/06/2018
Out of memory
Above error or program log occured at :07 30 02 19/06/2018
Above error or program log occured at :07 33 01 19/06/2018
Above error or program log occured at :07 33 02 19/06/2018
Out of memory
Above error or program log occured at :07 35 00 19/06/2018
Out of memory
Above error or program log occured at :07 35 04 19/06/2018
Out of memory
Above error or program log occured at :07 40 00 19/06/2018
Out of memory
Above error or program log occured at :07 40 03 19/06/2018
Out of memory
Above error or program log occured at :07 45 01 19/06/2018
Out of memory
Above error or program log occured at :07 45 02 19/06/2018
Above error or program log occured at :07 48 00 19/06/2018
Above error or program log occured at :07 48 01 19/06/2018
Out of memory
Above error or program log occured at :07 50 01 19/06/2018
Out of memory
Above error or program log occured at :07 50 02 19/06/2018
Out of memory
Above error or program log occured at :07 55 00 19/06/2018
Out of memory
Above error or program log occured at :07 55 01 19/06/2018
Above error or program log occured at :07 55 02 19/06/2018
Out of memory
Above error or program log occured at :08 00 00 19/06/2018
Out of memory
Above error or program log occured at :08 00 02 19/06/2018
error with file #2 Out of memory
Above error or program log occured at :08 03 01 19/06/2018
error with file #11 Out of memory
error with monthtodate graph 2 Out of memory
Above error or program log occured at :08 03 02 19/06/2018
Out of memory
Above error or program log occured at :08 05 01 19/06/2018
Out of memory
Above error or program log occured at :08 05 04 19/06/2018
Out of memory
Above error or program log occured at :08 10 01 19/06/2018
Out of memory
Above error or program log occured at :08 10 02 19/06/2018
Out of memory
Above error or program log occured at :08 15 01 19/06/2018
Out of memory
Above error or program log occured at :08 15 02 19/06/2018
Above error or program log occured at :08 18 00 19/06/2018
Above error or program log occured at :08 18 01 19/06/2018
Out of memory
Above error or program log occured at :08 20 01 19/06/2018
Out of memory
Above error or program log occured at :08 20 02 19/06/2018
Out of memory
Above error or program log occured at :08 25 00 19/06/2018
Out of memory
Above error or program log occured at :08 25 01 19/06/2018
Above error or program log occured at :08 25 03 19/06/2018
Out of memory
Above error or program log occured at :08 30 00 19/06/2018
Out of memory
Above error or program log occured at :08 30 01 19/06/2018
Above error or program log occured at :08 30 02 19/06/2018
Above error or program log occured at :08 33 01 19/06/2018
Above error or program log occured at :08 33 02 19/06/2018
Out of memory
Above error or program log occured at :08 35 00 19/06/2018
Out of memory
Above error or program log occured at :08 35 04 19/06/2018
Out of memory
Above error or program log occured at :08 40 01 19/06/2018
Out of memory
Above error or program log occured at :08 40 02 19/06/2018
Out of memory
Above error or program log occured at :08 45 01 19/06/2018
Out of memory
Above error or program log occured at :08 45 02 19/06/2018
Above error or program log occured at :08 48 00 19/06/2018
Above error or program log occured at :08 48 01 19/06/2018
Out of memory
Above error or program log occured at :08 50 00 19/06/2018
Out of memory
Above error or program log occured at :08 50 01 19/06/2018
Above error or program log occured at :08 50 04 19/06/2018
Out of memory
Above error or program log occured at :08 55 00 19/06/2018
Out of memory
Above error or program log occured at :08 55 02 19/06/2018
Out of memory
Above error or program log occured at :09 00 00 19/06/2018
Out of memory
Above error or program log occured at :09 00 02 19/06/2018
Above error or program log occured at :09 00 03 19/06/2018
Above error or program log occured at :09 03 00 19/06/2018
Above error or program log occured at :09 03 01 19/06/2018
Above error or program log occured at :09 03 02 19/06/2018
Out of memory
Above error or program log occured at :09 05 01 19/06/2018
Out of memory
Above error or program log occured at :09 05 05 19/06/2018
Out of memory
Above error or program log occured at :09 10 01 19/06/2018
Out of memory
Above error or program log occured at :09 10 03 19/06/2018
Not enough memory resources are available to process this command System.SysUtils at time/date 9:10:14:549 19/06/2018
Above error or program log occured at :09 10 14 19/06/2018
Not enough memory resources are available to process this command System.SysUtils at time/date 9:11:11:907 19/06/2018
Above error or program log occured at :09 11 11 19/06/2018
ERROR: Failed to allocate memory for GIF DIB System.SysUtils at time/date 9:11:13:781 19/06/2018
Above error or program log occured at :09 11 13 19/06/2018
ERROR: Failed to allocate memory for GIF DIB System.SysUtils at time/date 9:11:15:755 19/06/2018
Above error or program log occured at :09 11 15 19/06/2018
ERROR: Failed to allocate memory for GIF DIB System.SysUtils at time/date 9:11:17:755 19/06/2018
Above error or program log occured at :09 11 17 19/06/2018
ERROR: Failed to allocate memory for GIF DIB System.SysUtils at time/date 9:11:19:755 19/06/2018
Above error or program log occured at :09 11 19 19/06/2018
ERROR: Failed to allocate memory for GIF DIB System.SysUtils at time/date 9:11:21:753 19/06/2018
Above error or program log occured at :09 11 21 19/06/2018
ERROR: Failed to allocate memory for GIF DIB System.SysUtils at time/date 9:11:23:756 19/06/2018
Above error or program log occured at :09 11 23 19/06/2018
ERROR: Failed to allocate memory for GIF DIB System.SysUtils at time/date 9:11:25:754 19/06/2018
Above error or program log occured at :09 11 25 19/06/2018
ERROR: Failed to allocate memory for GIF DIB System.SysUtils at time/date 9:11:27:768 19/06/2018
Above error or program log occured at :09 11 27 19/06/2018
I see from that error that you must have setup speech in WD?
I wonder if
FLWeather
has that setup as well
Hi, yes, weather talker is setup and running
as a test, try turning that off maybe?
I
I still get lines and lines of the
that is a just a file error, i,e where the file was in use by the web cam program
one way to reduce that chance to have ticked create temporary file in the file save tab in the web cam program
Hi Brian, I have just turned off the weather talker, will see how it goes. Oh, there are no errors in the error log so far, this morning, I checked it when I 1st got up at 3:30am.
I now get crashes every 2 weeks or so. I don’t know what the messages for the last one were because I’m offsite and asked my family to reboot the PC. I’ve now upgraded to build 73. But the problem is when it crashes, the PC is non-responsive to any remote client (e.g. teamviewer).
It’s sure something with the Win update. How to go back?? Frustration is this OS and WD worked perfectly fine 24/7 and suddenly that’s not true anymore. Huh.
see how build 73 goes
Hi Brian, on b73, no weather talker running and wd shut down on its own after 2 days, this is the error report,
Part 1
Above error or program log occured at :06 06 09 22/06/2018
Above error or program log occured at :06 10 00 22/06/2018
Above error or program log occured at :06 10 01 22/06/2018
Above error or program log occured at :06 15 01 22/06/2018
Above error or program log occured at :06 18 04 22/06/2018
Above error or program log occured at :06 20 01 22/06/2018
Above error or program log occured at :06 25 01 22/06/2018
Above error or program log occured at :06 30 00 22/06/2018
Above error or program log occured at :06 30 01 22/06/2018
Above error or program log occured at :06 33 06 22/06/2018
Above error or program log occured at :06 35 00 22/06/2018
Above error or program log occured at :06 40 01 22/06/2018
Above error or program log occured at :06 45 01 22/06/2018
Above error or program log occured at :06 48 05 22/06/2018
Above error or program log occured at :06 50 01 22/06/2018
Above error or program log occured at :06 55 00 22/06/2018
Above error or program log occured at :07 00 00 22/06/2018
Above error or program log occured at :07 00 01 22/06/2018
Above error or program log occured at :07 03 06 22/06/2018
Above error or program log occured at :07 05 01 22/06/2018
Above error or program log occured at :07 10 03 22/06/2018
Above error or program log occured at :07 15 00 22/06/2018
Above error or program log occured at :07 18 06 22/06/2018
Above error or program log occured at :07 20 03 22/06/2018
Above error or program log occured at :07 25 01 22/06/2018
Above error or program log occured at :07 30 03 22/06/2018
Above error or program log occured at :07 33 07 22/06/2018
Above error or program log occured at :07 35 01 22/06/2018
Above error or program log occured at :07 40 01 22/06/2018
Above error or program log occured at :07 45 01 22/06/2018
Above error or program log occured at :07 48 01 22/06/2018
Out of memory
Above error or program log occured at :07 50 01 22/06/2018
Out of memory
Above error or program log occured at :07 50 02 22/06/2018
Out of memory
Above error or program log occured at :07 55 00 22/06/2018
Out of memory
Above error or program log occured at :07 55 02 22/06/2018
Out of memory
Above error or program log occured at :08 00 01 22/06/2018
Out of memory
Above error or program log occured at :08 00 02 22/06/2018
Above error or program log occured at :08 03 01 22/06/2018
Above error or program log occured at :08 03 02 22/06/2018
Out of memory
Above error or program log occured at :08 05 01 22/06/2018
Out of memory
Above error or program log occured at :08 05 06 22/06/2018
Out of memory
Above error or program log occured at :08 10 01 22/06/2018
Out of memory
Above error or program log occured at :08 10 03 22/06/2018
Out of memory
Above error or program log occured at :08 15 15 22/06/2018
Out of memory
Above error or program log occured at :08 15 16 22/06/2018
Above error or program log occured at :08 15 20 22/06/2018
Above error or program log occured at :08 18 00 22/06/2018
Above error or program log occured at :08 18 01 22/06/2018
Out of memory
Above error or program log occured at :08 20 01 22/06/2018
Out of memory
Above error or program log occured at :08 20 02 22/06/2018
Above error or program log occured at :08 20 03 22/06/2018
Out of memory
Above error or program log occured at :08 25 00 22/06/2018
Out of memory
Above error or program log occured at :08 25 01 22/06/2018
Above error or program log occured at :08 25 03 22/06/2018
error with mainform custom screen image Out of memory
Above error or program log occured at :08 28 01 22/06/2018
Above error or program log occured at :08 29 01 22/06/2018
Out of memory
Above error or program log occured at :08 30 01 22/06/2018
Out of memory
Above error or program log occured at :08 30 03 22/06/2018
Above error or program log occured at :08 31 01 22/06/2018
Above error or program log occured at :08 32 01 22/06/2018
Above error or program log occured at :08 33 01 22/06/2018
Above error or program log occured at :08 33 02 22/06/2018
Above error or program log occured at :08 33 03 22/06/2018
Above error or program log occured at :08 34 01 22/06/2018
Out of memory
Above error or program log occured at :08 35 00 22/06/2018
Out of memory
Above error or program log occured at :08 35 01 22/06/2018
Above error or program log occured at :08 35 05 22/06/2018
Above error or program log occured at :08 35 06 22/06/2018
Had to do it in 3 posts
part 2
Above error or program log occured at :08 36 01 22/06/2018
Above error or program log occured at :08 37 01 22/06/2018
Above error or program log occured at :08 38 02 22/06/2018
Above error or program log occured at :08 39 01 22/06/2018
Out of memory
Above error or program log occured at :08 40 01 22/06/2018
Out of memory
Above error or program log occured at :08 40 03 22/06/2018
Above error or program log occured at :08 41 01 22/06/2018
Above error or program log occured at :08 42 02 22/06/2018
Above error or program log occured at :08 43 01 22/06/2018
Above error or program log occured at :08 44 01 22/06/2018
Out of memory
Above error or program log occured at :08 45 01 22/06/2018
Out of memory
Above error or program log occured at :08 45 02 22/06/2018
Above error or program log occured at :08 46 02 22/06/2018
Above error or program log occured at :08 47 03 22/06/2018
Above error or program log occured at :08 48 00 22/06/2018
Above error or program log occured at :08 48 01 22/06/2018
Above error or program log occured at :08 48 02 22/06/2018
Above error or program log occured at :08 49 02 22/06/2018
Out of memory
Above error or program log occured at :08 50 01 22/06/2018
Out of memory
Above error or program log occured at :08 50 02 22/06/2018
Above error or program log occured at :08 51 03 22/06/2018
Above error or program log occured at :08 52 02 22/06/2018
Above error or program log occured at :08 53 01 22/06/2018
Above error or program log occured at :08 54 02 22/06/2018
Out of memory
Above error or program log occured at :08 55 00 22/06/2018
Out of memory
Above error or program log occured at :08 55 02 22/06/2018
Above error or program log occured at :08 56 01 22/06/2018
Above error or program log occured at :08 57 01 22/06/2018
Above error or program log occured at :08 58 02 22/06/2018
Above error or program log occured at :08 59 01 22/06/2018
Out of memory
Above error or program log occured at :09 00 01 22/06/2018
Out of memory
Above error or program log occured at :09 00 04 22/06/2018
Above error or program log occured at :09 01 02 22/06/2018
Above error or program log occured at :09 02 01 22/06/2018
Above error or program log occured at :09 03 01 22/06/2018
Above error or program log occured at :09 03 02 22/06/2018
Above error or program log occured at :09 03 03 22/06/2018
Above error or program log occured at :09 04 01 22/06/2018
Out of memory
Above error or program log occured at :09 05 00 22/06/2018
Out of memory
Above error or program log occured at :09 05 01 22/06/2018
Above error or program log occured at :09 05 05 22/06/2018
Above error or program log occured at :09 06 02 22/06/2018
Above error or program log occured at :09 07 01 22/06/2018
Above error or program log occured at :09 08 03 22/06/2018
Above error or program log occured at :09 09 02 22/06/2018
Out of memory
Above error or program log occured at :09 10 00 22/06/2018
Out of memory
Above error or program log occured at :09 10 01 22/06/2018
Above error or program log occured at :09 10 02 22/06/2018
Above error or program log occured at :09 11 01 22/06/2018
Above error or program log occured at :09 12 02 22/06/2018
Above error or program log occured at :09 13 01 22/06/2018
Above error or program log occured at :09 14 01 22/06/2018
Out of memory
Above error or program log occured at :09 15 00 22/06/2018
Out of memory
Above error or program log occured at :09 15 01 22/06/2018
Above error or program log occured at :09 15 02 22/06/2018
Above error or program log occured at :09 16 01 22/06/2018
Above error or program log occured at :09 17 02 22/06/2018
Above error or program log occured at :09 18 00 22/06/2018
Above error or program log occured at :09 18 01 22/06/2018
Above error or program log occured at :09 18 02 22/06/2018
Above error or program log occured at :09 19 02 22/06/2018
Out of memory
Above error or program log occured at :09 20 01 22/06/2018
Out of memory
Above error or program log occured at :09 20 04 22/06/2018
Part 3
Out of memory
Above error or program log occured at :09 50 02 22/06/2018
Above error or program log occured at :09 50 03 22/06/2018
Above error or program log occured at :09 51 01 22/06/2018
Above error or program log occured at :09 52 02 22/06/2018
Above error or program log occured at :09 53 01 22/06/2018
Above error or program log occured at :09 54 01 22/06/2018
Out of memory
Above error or program log occured at :09 55 00 22/06/2018
Out of memory
Above error or program log occured at :09 55 02 22/06/2018
Above error or program log occured at :09 55 03 22/06/2018
Above error or program log occured at :09 56 02 22/06/2018
Above error or program log occured at :09 57 01 22/06/2018
Above error or program log occured at :09 58 02 22/06/2018
Above error or program log occured at :09 59 01 22/06/2018
Out of memory
Above error or program log occured at :10 00 01 22/06/2018
Out of memory
Above error or program log occured at :10 00 04 22/06/2018
Above error or program log occured at :10 01 02 22/06/2018
Above error or program log occured at :10 02 01 22/06/2018
Above error or program log occured at :10 03 01 22/06/2018
Above error or program log occured at :10 03 02 22/06/2018
Above error or program log occured at :10 03 03 22/06/2018
Above error or program log occured at :10 04 02 22/06/2018
Out of memory
Above error or program log occured at :10 05 00 22/06/2018
Out of memory
Above error or program log occured at :10 05 01 22/06/2018
Above error or program log occured at :10 05 06 22/06/2018
Above error or program log occured at :10 06 01 22/06/2018
Above error or program log occured at :10 07 02 22/06/2018
Above error or program log occured at :10 08 02 22/06/2018
Above error or program log occured at :10 09 03 22/06/2018
Out of memory
Above error or program log occured at :10 10 00 22/06/2018
Out of memory
Above error or program log occured at :10 10 01 22/06/2018
Above error or program log occured at :10 10 02 22/06/2018
Above error or program log occured at :10 11 01 22/06/2018
Above error or program log occured at :10 12 01 22/06/2018
Above error or program log occured at :10 13 02 22/06/2018
Above error or program log occured at :10 14 01 22/06/2018
Out of memory
Above error or program log occured at :10 15 00 22/06/2018
Out of memory
Above error or program log occured at :10 15 01 22/06/2018
Above error or program log occured at :10 15 02 22/06/2018
Above error or program log occured at :10 16 02 22/06/2018
Above error or program log occured at :10 17 01 22/06/2018
Above error or program log occured at :10 18 01 22/06/2018
Above error or program log occured at :10 18 02 22/06/2018
Above error or program log occured at :10 18 03 22/06/2018
Above error or program log occured at :10 19 01 22/06/2018
Out of memory
Above error or program log occured at :10 20 01 22/06/2018
Out of memory
Above error or program log occured at :10 20 02 22/06/2018
Above error or program log occured at :10 20 03 22/06/2018
Above error or program log occured at :10 21 01 22/06/2018
Above error or program log occured at :10 22 03 22/06/2018
Not enough memory resources are available to process this command System.SysUtils at time/date 10:23:14:210 22/06/2018
Above error or program log occured at :10 23 14 22/06/2018
Not enough memory resources are available to process this command System.SysUtils at time/date 10:23:16:208 22/06/2018
Above error or program log occured at :10 23 16 22/06/2018
Out of memory
Above error or program log occured at :10 25 00 22/06/2018
