I’ve had it set to reboot the computer twice a week. I’ve now changed it to just restart WD every night.
One thing I notice is that when I have it set to restart WD, the WebCam capture program doesn’t close, and it opens a new instance of it, so there are two (or maybe more if I don’t check it) every time WD restarts. Is there any way to prevent multiple instances of that running after a WD restart?
Thank you, I’ll try this and let you know if it works.
which version of the wdwebcamcapture program?
Webcamcapture 10.05.
Same here, since the major spring update (Win10) WD will hang, i have just gotten into the habit of restarting it daily now, where can i set it to restart on its own please? i cannot find it
re wdwebcamcapture.exe
that is the latest version
what I will do is make sure that exists better when WD is restarted
(see in the ftp/internet setup, reboot)
@BWX,it would be good if you could provide more info, like, how often this happens etc
Thank you, Brian. So just monitor it until you can investigate?
actually the restart option uses the wdstartdelay.exe program
you can increase the time period…to allow the web cam program to exit first
try that
I set it for 90 seconds. I’ll let you know tomorrow if it worked! Fingers crossed.
I didnt pay it much attention Brian as it didnt bother me, i knew it was the windows update so it was my fault, i just started to reboot it every day and left it at that, i only replied to ask how to set WD to reboot automatically as i cannot find it
It’s under Control Panel>FTP Connections>Reboot/Restart/Exit
It seems like there’s a Windows update every other day lately. Hopefully they’re fixing their prior crappy releases.
Brian, the 90 seconds delay worked. It gave the Webcamcapture.exe program enough time to close so a new version could start by itself.
Thank you.
@ BMX
I think your issue is more a driver issue
try updating to the latest silicon labs driver available
Thanks ever so much, didnt think to look in there.
I have just done this again now without issues this time, i noticed in the history that SL updated the drivers during May, looks like they have fixed what ever issues i had, thanks Brian, PS, i tried updating via the device manage but it failed with regards to an inf file, so i had to do it manually, downloading from SL
2 Days running and it crashes, well, not so much crashes, but it stops all data upload, wd is still getting data from the davis, but i cannot view any icons on the View screen but i can click the buttons, the wind dial disappears from the main screen, i cannot however close WD, not even from the task manager, this was why i resorted to just rebooting WD and it only ever happens during the night, WD only used 270mb out of 8gb and it only started after the spring update.
Memory test results: No errors detected
Error log
Above error or program log occured at :04 55 00 15/06/2018
error with house keeping Access violation at address 0088A850 in module 'WeatherDisplay.exe'. Write of address 00000000
Above error or program log occured at :22 01 10 15/06/2018
error with do timer 1 via units Thread creation error: Not enough memory resources are available to process this command
Above error or program log occured at :22 02 00 15/06/2018
Above error or program log occured at :22 03 00 15/06/2018
Above error or program log occured at :22 04 00 15/06/2018
Above error or program log occured at :22 05 00 15/06/2018
Above error or program log occured at :22 10 00 15/06/2018
Above error or program log occured at :22 10 01 15/06/2018
Above error or program log occured at :22 11 00 15/06/2018
Above error or program log occured at :22 12 00 15/06/2018
Above error or program log occured at :22 13 00 15/06/2018
some good clues there
try build 73:
Thank you, i will let you know, normally happens after 2 nights if it going to happen
I have not forgot to let you know, what i did was forget to turn off the auto reboot, its up to 66500 data count @81mb used, it would normally hang or whatever it does tonight, being the 2nd night, but i will give it another couple of nights if its ok tonight, then let you know.
I think I have fixed it, hopefully
strange that it was OK until a change in windows version
Ha ha, ya not gonna believe this, just got back in and WD had closed itself and the error log shows all this, i cant believe it after my post this morning, talk about tempting fate 8O
error with house keeping Access violation at address 0088A850 in module 'weatherdisplay.exe'. Write of address 00000000
Above error or program log occured at :06 06 09 19/06/2018
error with speech click Not enough memory resources are available to complete this operation
Above error or program log occured at :06 10 00 19/06/2018
Above error or program log occured at :06 10 01 19/06/2018
Above error or program log occured at :06 15 00 19/06/2018
error with monthtodate graph Out of memory
Above error or program log occured at :06 18 05 19/06/2018
Above error or program log occured at :06 20 01 19/06/2018
Above error or program log occured at :06 25 00 19/06/2018
Above error or program log occured at :06 30 01 19/06/2018
Above error or program log occured at :06 33 06 19/06/2018
Above error or program log occured at :06 35 02 19/06/2018
Above error or program log occured at :06 40 03 19/06/2018
Above error or program log occured at :06 45 01 19/06/2018
Above error or program log occured at :06 48 04 19/06/2018
Above error or program log occured at :06 50 01 19/06/2018
Above error or program log occured at :06 55 01 19/06/2018
Above error or program log occured at :07 00 01 19/06/2018
Above error or program log occured at :07 03 06 19/06/2018
Above error or program log occured at :07 05 01 19/06/2018
Above error or program log occured at :07 10 01 19/06/2018
Above error or program log occured at :07 15 01 19/06/2018
Above error or program log occured at :07 18 04 19/06/2018
Above error or program log occured at :07 20 01 19/06/2018
Above error or program log occured at :07 25 01 19/06/2018
Above error or program log occured at :07 26 32 19/06/2018
Out of memory
Above error or program log occured at :07 30 01 19/06/2018
Out of memory
Above error or program log occured at :07 30 02 19/06/2018
Above error or program log occured at :07 33 01 19/06/2018
Above error or program log occured at :07 33 02 19/06/2018
Out of memory
Above error or program log occured at :07 35 00 19/06/2018
Out of memory
Above error or program log occured at :07 35 04 19/06/2018
Out of memory
Above error or program log occured at :07 40 00 19/06/2018
Out of memory
Above error or program log occured at :07 40 03 19/06/2018
Out of memory
Above error or program log occured at :07 45 01 19/06/2018
Out of memory
Above error or program log occured at :07 45 02 19/06/2018
Above error or program log occured at :07 48 00 19/06/2018
Above error or program log occured at :07 48 01 19/06/2018
Out of memory
Above error or program log occured at :07 50 01 19/06/2018
Out of memory
Above error or program log occured at :07 50 02 19/06/2018
Out of memory
Above error or program log occured at :07 55 00 19/06/2018
Out of memory
Above error or program log occured at :07 55 01 19/06/2018
Above error or program log occured at :07 55 02 19/06/2018
Out of memory
Above error or program log occured at :08 00 00 19/06/2018
Out of memory
Above error or program log occured at :08 00 02 19/06/2018
error with file #2 Out of memory
Above error or program log occured at :08 03 01 19/06/2018
error with file #11 Out of memory
error with monthtodate graph 2 Out of memory
Above error or program log occured at :08 03 02 19/06/2018
Out of memory
Above error or program log occured at :08 05 01 19/06/2018
Out of memory
Above error or program log occured at :08 05 04 19/06/2018
Out of memory
Above error or program log occured at :08 10 01 19/06/2018
Out of memory
Above error or program log occured at :08 10 02 19/06/2018
Out of memory
Above error or program log occured at :08 15 01 19/06/2018
Out of memory
Above error or program log occured at :08 15 02 19/06/2018
Above error or program log occured at :08 18 00 19/06/2018
Above error or program log occured at :08 18 01 19/06/2018
Out of memory
Above error or program log occured at :08 20 01 19/06/2018
Out of memory
Above error or program log occured at :08 20 02 19/06/2018
Out of memory
Above error or program log occured at :08 25 00 19/06/2018
Out of memory
Above error or program log occured at :08 25 01 19/06/2018
Above error or program log occured at :08 25 03 19/06/2018
Out of memory
Above error or program log occured at :08 30 00 19/06/2018
Out of memory
Above error or program log occured at :08 30 01 19/06/2018
Above error or program log occured at :08 30 02 19/06/2018
Above error or program log occured at :08 33 01 19/06/2018
Above error or program log occured at :08 33 02 19/06/2018
Out of memory
Above error or program log occured at :08 35 00 19/06/2018
Out of memory
Above error or program log occured at :08 35 04 19/06/2018
Out of memory
Above error or program log occured at :08 40 01 19/06/2018
Out of memory
Above error or program log occured at :08 40 02 19/06/2018
Out of memory
Above error or program log occured at :08 45 01 19/06/2018
Out of memory
Above error or program log occured at :08 45 02 19/06/2018
Above error or program log occured at :08 48 00 19/06/2018
Above error or program log occured at :08 48 01 19/06/2018
Out of memory
Above error or program log occured at :08 50 00 19/06/2018
Out of memory
Above error or program log occured at :08 50 01 19/06/2018
Above error or program log occured at :08 50 04 19/06/2018
Out of memory
Above error or program log occured at :08 55 00 19/06/2018
Out of memory
Above error or program log occured at :08 55 02 19/06/2018
Out of memory
Above error or program log occured at :09 00 00 19/06/2018
Out of memory
Above error or program log occured at :09 00 02 19/06/2018
Above error or program log occured at :09 00 03 19/06/2018
Above error or program log occured at :09 03 00 19/06/2018
Above error or program log occured at :09 03 01 19/06/2018
Above error or program log occured at :09 03 02 19/06/2018
Out of memory
Above error or program log occured at :09 05 01 19/06/2018
Out of memory
Above error or program log occured at :09 05 05 19/06/2018
Out of memory
Above error or program log occured at :09 10 01 19/06/2018
Out of memory
Above error or program log occured at :09 10 03 19/06/2018
Not enough memory resources are available to process this command System.SysUtils at time/date 9:10:14:549 19/06/2018
Above error or program log occured at :09 10 14 19/06/2018
Not enough memory resources are available to process this command System.SysUtils at time/date 9:11:11:907 19/06/2018
Above error or program log occured at :09 11 11 19/06/2018
ERROR: Failed to allocate memory for GIF DIB System.SysUtils at time/date 9:11:13:781 19/06/2018
Above error or program log occured at :09 11 13 19/06/2018
ERROR: Failed to allocate memory for GIF DIB System.SysUtils at time/date 9:11:15:755 19/06/2018
Above error or program log occured at :09 11 15 19/06/2018
ERROR: Failed to allocate memory for GIF DIB System.SysUtils at time/date 9:11:17:755 19/06/2018
Above error or program log occured at :09 11 17 19/06/2018
ERROR: Failed to allocate memory for GIF DIB System.SysUtils at time/date 9:11:19:755 19/06/2018
Above error or program log occured at :09 11 19 19/06/2018
ERROR: Failed to allocate memory for GIF DIB System.SysUtils at time/date 9:11:21:753 19/06/2018
Above error or program log occured at :09 11 21 19/06/2018
ERROR: Failed to allocate memory for GIF DIB System.SysUtils at time/date 9:11:23:756 19/06/2018
Above error or program log occured at :09 11 23 19/06/2018
ERROR: Failed to allocate memory for GIF DIB System.SysUtils at time/date 9:11:25:754 19/06/2018
Above error or program log occured at :09 11 25 19/06/2018
ERROR: Failed to allocate memory for GIF DIB System.SysUtils at time/date 9:11:27:768 19/06/2018
Above error or program log occured at :09 11 27 19/06/2018
I see from that error that you must have setup speech in WD?
I wonder if
FLWeather
has that setup as well
Hi, yes, weather talker is setup and running
