Crashed again tonight. Looking at task manager, nothing is over 50mb memory. Total RAM is 4.6 GB out of 8GB.
I don’t know why WD is reporting out of system resources when noting is ever maxed out. I get this error again in the error log before it states ou of system resources:
Above error or program log occured at :00 53 00 05/18/2018
error create custom screen Cannot open file “C:\wdisplay\webcam\jpgwebcam.jpg”. The process cannot access the file because it is being used by another process
Above error or program log occured at :01 42 00 05/18/2018
Above error or program log occured at :02 06 00 05/18/2018
I do have it in use. It was 1.31 gb of pictures. I also deleted everything in the alldayvideo folder, that was 20 gb.
It should be noted that sometimes I see multiple icons of webcamcapture, realtimeclientraw ftp, and all WD associated icons in the running programs list where the icons are on the lower right side by the clock. I reboot when I see that and it all goes back to normal.
So far, so good. I still get the errors “error create custom screen Cannot open file “C:\wdisplay\webcam\jpgwebcam.jpg”. The process cannot access the file because it is being used by another process” about 6-10 times a day.
WD is using 410 mb memory at the moment. Broken up like this:
Weather Display: 379mb
For home weather stations(with a camera icon): 19mb
FTP: 4mb
croncloud: 4mb
WUrapidfire: 3mb
For home weather stations (with an earth icon): 3mb
Should WD use so much memory, or do I have some settings wrong in the program? I havge it set to reboot the computer twice a week to avoid freezing, but sometimes it still does.
Crashed again today.
One common thing I’m noticing in the program error log is that before it states out of system resources, there’s an error with the winddirplot each time:
“error with winddirplot Out of system resources
Above error or program log occured at :09 30 02 05/25/2018
ERROR: Out of system resources System.Classes at time/date 9:31:1:572 05/25/2018
Above error or program log occured at :09 31 01 05/25/2018”
I checked task manager and it was not maxed out anywhere. 47% mem usage.
Crashed again.
How do I turn off the custom screen? This is getting frustrating!!
That particular error is not likely the cause
But might be
What is the frequency you have for the file saving of the
Webcam image in the wdwebcamcapture program?
You could try reducing that
Under Action>Webcam, I have files set to save at 1 minute intervals as well under time stamped files setup. Actually the produce every minute and every 30 second override is also checked. I don’t know if there are any conflicts with how I have things set up in this whole section.
I’m not sure it’s related but it happened twice (2) in the last 3 weeks that WD crashed.
What happened:
WD stopped updating the FTP
A flood of Windows system messages on the screen (see below)
When I closed all messages, WD still did work and was taking data from the station (Davis)
I exited WD and restarted it again. A new system message popped up (see below)
Reboot the PC, all OK
Message 1:
Exception EReadError in module ftpupd.exe at 00026C52
Error reading tollstmemo.Lines.Strings::System Error. Code: 8.
Not enough memory resources are available to process this
command.
Message 2:
Exception EOSError in module WeatherDisplay.exe at
0003A325.
command.
My laptop is HP EliteBook, Windows10, WD build 68.
I have a 1-wire USB interface taking data from 5 extra temp sensors and do per-minute http downloads and 5 min FTP uploads. RapidFire WU enabled, 2-second clientraw uploads.
