Author Topic: Weekly crashes  (Read 6585 times)
Offline BWX
  • Win NT 10.0
  • Chrome 67.0.3396.87
    • Breckland Weather
Re: Weekly crashes
« Reply #60 on: June 23, 2018, 04:21:54 AM »
Update: an hour later its down to 180mb now, not sure why though
Offline BWX
  • Win NT 10.0
    • Breckland Weather
Re: Weekly crashes
« Reply #61 on: June 24, 2018, 04:22:25 AM »
Happened again early hours, started from 10pm last night though, watchdog restarted but didnt restart webcamcapture, clientraw and WU as i had 2 instances of those running, errorlog attached (hopefully)
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
Re: Weekly crashes
« Reply #62 on: June 24, 2018, 05:30:49 AM »
the next thing you could test then is to disable the custom screen images
Offline BWX
  • Win NT 10.0
    • Breckland Weather
Re: Weekly crashes
« Reply #63 on: June 24, 2018, 07:31:56 AM »
Ok, turned them off now.
Offline BWX
  • Win NT 10.0
  • Chrome 67.0.3396.99
    • Breckland Weather
Re: Weekly crashes
« Reply #64 on: June 26, 2018, 07:52:46 AM »
I reinstalled WD from full on the 24th, with weather talker off and custom images (main screen) off too, everything was ok this morning having scored 70k+ on the data count, normally gives in around the 50 mark. With that in mind i turn back on weather talker, seems ok for an hour, so i turned on mains screen custom images too, shortly after, the errors started rolling in again, for example
Code: [Select]
error with file #2 Out of memory
Above error or program log occured at :08 33 00 26/06/2018
error with file #11 Out of memory
Above error or program log occured at :08 33 01 26/06/2018
error with monthtodate graph Out of memory
error with monthtodate graph 2 Out of memory
Above error or program log occured at :08 33 02 26/06/2018
I turned off weather talker and still the errors came, turned off custom images and still they came, so at a loss atm, its either weather talker or custom images or both or has to be both working, i dont know, im guessing.
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
Re: Weekly crashes
« Reply #65 on: June 26, 2018, 08:48:40 AM »
you would need to restart WD and then test
Offline BWX
  • Win NT 10.0
    • Breckland Weather
Re: Weekly crashes
« Reply #66 on: June 26, 2018, 10:11:26 AM »
Already on it, i rebooted the laptop and weather talker is now running but not the custom mains screen images, will need a couple of days to see what happens
Offline BWX
  • Win NT 10.0
    • Breckland Weather
Re: Weekly crashes
« Reply #67 on: June 28, 2018, 05:52:45 AM »
Sadly the errors started within the last hour, no issues in WD yet, thats with the custom images turned off :(
Edit: cannot open FTP/Connections in control panel, everything else opens in there ok
« Last Edit: June 28, 2018, 05:54:41 AM by BWX »
Offline BWX
  • Win NT 10.0
    • Breckland Weather
Re: Weekly crashes
« Reply #68 on: June 28, 2018, 04:44:15 PM »
We can definitely rule out main screen custom images and weather talker, both were disabled and the errors started up on the error log this afternoon :(
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
Re: Weekly crashes
« Reply #69 on: June 28, 2018, 07:17:45 PM »
I can only suggest to try testing with disabling other functions you have setup until you find the problem with your setup
Offline mihec
  • (Linux Mint)
  • Firefox 60.0
Re: Weekly crashes
« Reply #70 on: July 03, 2018, 09:25:03 PM »
I'm seeing this error more and more frequent. It is not a bug which can be avoided but it's critical to 24/7 operation. I can not leave my PC unattended anymore. To recover from the blocked state, a hard power OFF is required.  It's most probably Win10 related but this did not happen until the last update. Is WD using some functions that are not supported by the new Microsoft drivers?
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
Re: Weekly crashes
« Reply #71 on: July 03, 2018, 09:41:55 PM »
what weather station type?
and are you using build 73 of WD?
Offline mihec
  • Android 5.0.2
  • Chrome 56.0.2924.87
Re: Weekly crashes
« Reply #72 on: July 03, 2018, 10:51:26 PM »
It is Davis Vantage Pro2, Win 10 64bit, WD b73
I'm off my home location to provide more data. Will be back in a week.
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
Re: Weekly crashes
« Reply #73 on: July 03, 2018, 10:54:10 PM »
the more information you can provide, the better
e.g what do you have set up in WD, etc
just saying you have a problem does not help
Offline mihec
  • Android 5.0.2
Re: Weekly crashes
« Reply #74 on: July 03, 2018, 11:50:43 PM »
This is my first report of the issue (see below). I haven't changed anything since only the WD build to 73. I hesitate to set restart WD daily but will test that next week.
The only change I needed to do after the Win update was reinstall the Silicon USB driver and changed the virtual COM port number.
Is there an option to revert the Windows update?
Must be something that triggers the hang. If it was a constant memory leak one would see it from the Task manager.
I'm not sure it's related but it happened twice (2) in the last 3 weeks that WD crashed.
What happened:
  • WD stopped updating the FTP
  • A flood of Windows system messages on the screen (see below)
  • When I closed all messages, WD still did work and was taking data from the station (Davis)
  • I exited WD and restarted it again. A new system message popped up (see below)
  • Reboot the PC, all OK
Message 1:
Exception EReadError in module ftpupd.exe at 00026C52
Error reading tollstmemo.Lines.Strings::System Error. Code: 8.
Not enough memory resources are available to process this
command.
Message 2:
Exception EOSError in module WeatherDisplay.exe at
0003A325.
command.
My laptop is HP EliteBook, Windows10, WD build 68.
I have a 1-wire USB interface taking data from 5 extra temp sensors and do per-minute http downloads and 5 min FTP uploads. RapidFire WU enabled, 2-second clientraw uploads.
Is this a Windows bug or is it WD related?
