Author Topic: Weekly crashes  (Read 5766 times)
Offline FLWeather
  • Jupiter, FL
  • Win NT 10.0
  • Firefox 60.0
    • Live Jupiter, FL Weather
Re: Weekly crashes
« Reply #30 on: June 12, 2018, 12:24:29 AM »
Webcamcapture 10.05.
Offline BWX
  • Win NT 10.0
  • Chrome 67.0.3396.79
Re: Weekly crashes
« Reply #31 on: June 12, 2018, 06:08:12 AM »
Same here, since the major spring update (Win10) WD will hang, i have just gotten into the habit of restarting it daily now, where can i set it to restart on its own please? i cannot find it
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
Re: Weekly crashes
« Reply #32 on: June 12, 2018, 06:27:36 PM »
re wdwebcamcapture.exe
that is the latest version
what I will do is make sure that exists better when WD is restarted
(see in the ftp/internet setup, reboot)
@BWX,it would be good if you could provide more info, like, how often this happens etc
Offline FLWeather
  • Jupiter, FL
  • Win NT 10.0
  • Firefox 60.0
Re: Weekly crashes
« Reply #33 on: June 13, 2018, 12:12:35 AM »
Thank you, Brian. So just monitor it until you can investigate?
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
Re: Weekly crashes
« Reply #34 on: June 13, 2018, 12:57:03 AM »
actually the restart option uses the wdstartdelay.exe program
you can increase the time period...to allow the web cam program to exit first
try that
Offline FLWeather
  • Jupiter, FL
  • Win NT 10.0
  • Firefox 60.0
Re: Weekly crashes
« Reply #35 on: June 13, 2018, 03:15:34 AM »
I set it for 90 seconds. I'll let you know tomorrow if it worked! Fingers crossed.
Offline BWX
  • Win NT 10.0
Re: Weekly crashes
« Reply #36 on: June 13, 2018, 12:10:09 PM »
I didnt pay it much attention Brian as it didnt bother me, i knew it was the windows update so it was my fault, i just started to reboot it every day and left it at that, i only replied to ask how to set WD to reboot automatically as i cannot find it
Offline FLWeather
  • Jupiter, FL
  • Win NT 10.0
  • Firefox 60.0
Re: Weekly crashes
« Reply #37 on: June 13, 2018, 02:50:12 PM »
It's under Control Panel>FTP Connections>Reboot/Restart/Exit
It seems like there's a Windows update every other day lately. Hopefully they're fixing their prior crappy releases.
Brian, the 90 seconds delay worked. It gave the Webcamcapture.exe program enough time to close so a new version could start by itself.
Thank you. :)
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
Re: Weekly crashes
« Reply #38 on: June 13, 2018, 07:30:55 PM »
@ BMX
I think your issue is more a driver issue
try updating to the latest silicon labs driver available
Offline BWX
  • Win NT 10.0
  • Chrome 67.0.3396.87
Re: Weekly crashes
« Reply #39 on: June 14, 2018, 07:28:47 AM »
Thanks ever so much, didnt think to look in there.
@ BMX
I have just done this again now without issues this time, i noticed in the history that SL updated the drivers during May, looks like they have fixed what ever issues i had, thanks Brian, PS, i tried updating via the device manage but it failed  with regards to an inf file, so i had to do it manually, downloading from SL
Offline BWX
  • Win NT 10.0
Re: Weekly crashes
« Reply #40 on: June 16, 2018, 03:31:02 AM »
2 Days running and it crashes, well, not so much crashes, but it stops all data upload, wd is still getting data from the davis, but i cannot view any icons on the View screen but i can click the buttons, the wind dial disappears from the main screen, i cannot however close WD, not even from the task manager, this was why i resorted to just rebooting WD and it only ever happens during the night, WD only used 270mb out of 8gb and it only started after the spring update.
Memory test results: No errors detected
Error log
Code: [Select]
Above error or program log occured at :04 55 00 15/06/2018
error with house keeping Access violation at address 0088A850 in module 'WeatherDisplay.exe'. Write of address 00000000
Above error or program log occured at :22 01 10 15/06/2018
error with do timer 1 via units Thread creation error: Not enough memory resources are available to process this command
Above error or program log occured at :22 02 00 15/06/2018
Above error or program log occured at :22 03 00 15/06/2018
Above error or program log occured at :22 04 00 15/06/2018
Above error or program log occured at :22 05 00 15/06/2018
Above error or program log occured at :22 10 00 15/06/2018
Above error or program log occured at :22 10 01 15/06/2018
Above error or program log occured at :22 11 00 15/06/2018
Above error or program log occured at :22 12 00 15/06/2018
Above error or program log occured at :22 13 00 15/06/2018
« Last Edit: June 16, 2018, 04:20:52 AM by BWX »
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
Re: Weekly crashes
« Reply #41 on: June 16, 2018, 04:56:00 AM »
Offline BWX
  • Win NT 10.0
Re: Weekly crashes
« Reply #42 on: June 16, 2018, 09:22:24 AM »
Thank you, i will let you know, normally happens after 2 nights if it going to happen
Offline BWX
  • Win NT 10.0
Re: Weekly crashes
« Reply #43 on: June 19, 2018, 07:24:31 AM »
I have not forgot to let you know, what i did was forget to turn off the auto reboot, its up to 66500 data count @81mb used, it would normally hang or whatever it does tonight, being the 2nd night, but i will give it another couple of nights if its ok tonight, then let you know.
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
Re: Weekly crashes
« Reply #44 on: June 19, 2018, 09:43:58 AM »
I think I have fixed it, hopefully
strange that it was OK until a change in windows version
