Wrong reading for Netatmo Outdoor sensor
WD now showing the same temperature as the indoor at the outdoor reading. It is ok at the Netatmo mobile app. (started yesterday)
Since yesterday the same thing happens to me. Does anyone know what happens?
anything else change?
i.e did you update WD, or?
if not, then it must be some change made with the Netatmo servers
I would need to know someones Netatmo login details for me to test here
No, not change anything, and no sw update. If you send me an e-mail, you can “borrow” an account from me.
In my case I tried to upgrade from build 66 to 70 to see if it corrected the problem, and still with the same error. I also received emails from netatmo saying that I was blocking access to an external application. I have confirmed that the access is authorized but the error follows.
I can send my passwords via email, if necessary.
Thank you
looks like it was a change made by the Netatmo servers
I have fixed it in build 71 now
Thanks. I installed the build 71 now, and now it looks like things are OK.
The same problem follows me. I upgraded to build 71, should I install wd from scratch instead of updating?
do you mean build 71 is not working correctly for you, or?
Hi!
The issue remaine: the same temperature as the indoor at the outdoor…
yes, the problem still continues
I did duplicate and then I did fix this issue
I would need to know your email and password to test/check here
HI
OK
should be fixed with build 72 .zip update
Thanks !! now it works
that’s good
I should have coded it this way the first time
