I had a power outage at home today for about 4 hours and also Wednesday. I’m trying to extract the data for the downtime from the logger but when i click Extract data from logger the action box pops up and stays at 0%. I’m running the latest version of WD. Live data is updating from the logger so they are communicating. Any help would be great.
try instead
go to control panel , data logger
and there set the time/date to get the data from
click on OK
then exit WD and restart
I gave that a try Brian but still the same result. Action box pops up but stays at 0% indefinitely.
what shows under view, debug info?
Nothing in there related to the problem
well, that would be better for me to decide I would think?
Very hard to pinpoint the exact text as it runs so fast but basically its says
Asking for archived data download
Davis VP Retrieving data from: day 29 month 4 year 2018
Retrieving data from: hour 11 minute 21
ask for time/date of record…
1 6 1
1 1 2
1 2 3
1 0 4
1 0 5
1 24 6
1 212 7
Sending OK…
Then when i abort it records that in the log.
what data logging interval is the data logger set to?
is the time/date on the data logger the same as the pc?
Interval is set to 1 minute.
Time and date are the same on the logger and pc.
I am not sure what is wrong
but one thing that seems to work is to do a complete reset of the data logger
(i.e power down console, remove data logger for 5 minutes, re power up console, re setup it up (set 1 minute logging interval and time/date)
(but you would want to use another way of getting the current missed data into WD, eg via the weatherlink .wlk file)
Thanks Brian, bit of a messy way to get the data retrieved but needs must i guess.
