I’m trying to get UV data from UVN800 UV sensor in WD. On main station UV value is receiving with no problems.
In WD UV value is always zero, but it’s read raw data on sensor #4.
ah, I see its an optional UV sensor
(but no solar sensor?)
I would need to add support for a uv sensor
to do that I would need to get some raw data from you (via a test version of WD)
Yes, just UV sensor.
How to get raw data?
I would need to get you a version that will get /show that
try this update
and see what shows under view, debug info
when you have different UV values
Maybe this can help you
UV 2 on display
179 UV raw 1 242
179 UV raw 2 179
179 UV raw 3 5
179 UV raw 4 2
UV 3 on display
179 UV raw 1 242
179 UV raw 2 179
179 UV raw 3 5
179 UV raw 4 3
UV 4 on display
179 UV raw 1 242
179 UV raw 2 179
179 UV raw 3 5
179 UV raw 4 4
excellent
there is the raw data
I will work on adding that into WD today and let you know
try this update
you should see the UV data above the wind direction hopefully
and you should be able to set to plot it too in the graph setup
I have removed the debug info
It’s working now, thanks for fast upgrade
