looks like its only a problem when not using metric
I will look into it for the next update
Thanks Brian
Also, noticed on the same screen that the weather conditions is showing Dry when in fact that it’s raining at all locations. Must be tied in with something.
that data is more for when you are using clientraw.txt data as the source
i.e Dry is just the default
I think you will find
for the month rain and WU data
try this update
Brian,
That fixed the issued with the weathermap setup. Thanks…
Brian I spoke too soon. After checking this morning, the figures stayed the same. Below is the correct rainfall for today.
Mt Mitchell, NC 0.08
Nebo, NC 0.05
Black Mountain, NC 0.02
Hanging Rock 0.57
Marion, NC 0.06
so now the problem is the rain today is not updating, or?
(its not very clear)
Yes, the rain today is not updating.
so it was OK initially, but then was not, or?
the more detailed information you can provide, the better
When I initially installed the program that you sent me the info was correct. This morning, I noticed that the information was the same as when the program was installed so it did not update. The Daily Rain Amounts are not updating. Also, the temps are updating are showing the correct information and have been all along.
we have rain here in this area today so will so some testing
try a new .zip update, should fix this issue
Still same problem. Temps are updating but not the rain.
that is strange
as I found the problem and fixed it
are you sure you are using the latest .zip update from the WD download page?
Yes, I downloaded the newest version yesterday, but just to be sure, I downloaded the same version today and still get unusual readings from the rain amounts.
are you sure you are using the .zip update?
as its working ok here in testing
Yes. Will re-install again and see if that makes a difference. Re-installed the program and I am getting the following.
Your program is showing. Site is showing
Mt Mitchell, NC 0.028 Actual 0.0
Nebo, NC 0.476 0.0
Black Mountain, NC 0.283 0.0
Hanging Rock, NC 0.283 0.0
Marion, NC 0.327 0.0
Above are the numbers that I am getting today. That doesn’t look like it’s working to me. The Temps and Humidity are correct.
if you could .zip and email me your settings files
I will check/test here
(see the FAQ on how to do that)
are you using the .zip update?
I sent the files and yes, I am using the zip that you sent…
