Author Topic: SteelSeries graphs not consistent  (Read 4749 times)
Offline TheBreeze
  • Craig
  • On Lake Ontario, Rochester, N.Y. - Davis VP2 Plus
  • Win NT 10.0
  • Chrome 65.0.3325.181
    • WDL
Re: SteelSeries graphs not consistent
« Reply #30 on: April 26, 2018, 09:28:57 PM »
N - I think I have all the pointers going to the correct folders.  There are only 3 or 4 places to configure, right?
Craig
Lake Ontario Weather  www.cdcpcconsulting.com/Webster_Weather
AMD FX 6300 6 Core with 8 GB Mem, 320Gb Raptor SATA Raid,  NVidia GT 240 PCIe Video, Windows 10 Pro 64 bit dedicated Weather Machine
Running WD 10.37S63 WDL 6.09
Offline niko
  • syzygy
  • Global Moderator
  • Northern California, U.S.A.
  • Win 7/Srvr 2008R2
  • Chrome 66.0.3359.117
« Reply #31 on: April 26, 2018, 09:43:25 PM »
I don't see that as a problem. I think it may be worth trying a different jpgraph version.
Offline broadstairs
  • Stuart
  • Broadstairs, Kent, UK
  • (Linux Mint)
  • Firefox 56.0
    • Broadstairs
« Reply #32 on: April 26, 2018, 09:47:22 PM »
I just saw this and decided to try jpgraph 4.2.0 with my copy of the graphs on PHP 7 and it works fine both locally here on my own server and on my live website. So yes the issue is as has been suggested.
Offline niko
  • syzygy
  • Global Moderator
  • Win 7/Srvr 2008R2
« Reply #33 on: April 26, 2018, 09:58:13 PM »
Thanks Stuart. I now tried 4.0.1 on Craig's server and it doesn't change the problem with wxgraphs or the jpgraph examples. I don't know what else to do :dontknow:
Offline broadstairs
  • Stuart
  • (Linux Mint)
  • Firefox 56.0
    • Broadstairs
« Reply #34 on: April 26, 2018, 10:09:55 PM »
Yup I took a look again at his steel gauges and sure enough it's a lottery as to which graphs pop up and which dont. There's something very strange with the server.
Offline niko
  • syzygy
  • Global Moderator
  • Win 7/Srvr 2008R2
« Reply #35 on: April 26, 2018, 10:17:29 PM »
Same on the test page http://www.cdcpcconsulting.com/wxgraphs/wxgraphs_test.html
For whatever reason each graph is using a lot of memory, so one or two are OK, but more than that and the server can't/won't handle it  :?
Offline broadstairs
  • Stuart
  • (Linux Mint)
  • Firefox 56.0
    • Broadstairs
« Reply #36 on: April 26, 2018, 10:27:02 PM »
Exactly what level of PHP is the server running? Is it user selectable in CPanel, some systems allow different versions of PHP to be selected and if so might be worth trying a different PHP version.
Offline niko
  • syzygy
  • Global Moderator
  • Win 7/Srvr 2008R2
« Reply #37 on: April 26, 2018, 10:33:42 PM »
It's 5.4.36, I'll see if there are any options.
Offline broadstairs
  • Stuart
  • (Linux Mint)
  • Firefox 56.0
    • Broadstairs
« Reply #38 on: April 26, 2018, 10:37:12 PM »
I can select it on my system. Currently running 7.2 and it's all OK. I can try older ones so just tried 5.4 and it works fine almost instant display of all graphs just fine.
Offline niko
  • syzygy
  • Global Moderator
  • Win 7/Srvr 2008R2
« Reply #39 on: April 26, 2018, 11:10:48 PM »
There's a warning message:
Warning: Changing php modules and php options via PHP Selector for native php version is impossible
and it currently shows running "native (5.4)" - I'm not really sure what that means but it's not my server so I'm reluctant to mess with it.
Offline TheBreeze
  • Craig
  • Win NT 10.0
    • WDL
« Reply #40 on: April 26, 2018, 11:47:35 PM »
I appreciate both of your trying to get to the bottom of this, but as an average user, I am in about 2 feet over my head.. and can add nothing.
If I could disable the graph function I would, but when I renamed the JP and WX folders, I got 10 errors for file not found when the SteelSeries page loaded...  It is just a little frustrating..
Offline broadstairs
  • Stuart
  • (Linux Mint)
  • Firefox 56.0
    • Broadstairs
« Reply #41 on: April 27, 2018, 06:02:04 AM »
I do think that means you are unable to change those options for the default PHP but can alter them when not using the default. However I agree with you and would not change anything for someone else's server just in case  :wink:
Offline mcrossley
  • Wilmslow, Cheshire, UK
    • none
  • Win NT 10.0
  • Chrome 66.0.3359.139
    • WilmslowAstro Weather
« Reply #42 on: April 27, 2018, 01:03:24 PM »
In Gauges.js, look at line 51...
Code: [Select]
            showPopupGraphs    : true,                   // If pop-up data is displayed, show the graphs?
Just set that to false...
Code: [Select]
            showPopupGraphs    : false,                   // If pop-up data is displayed, show the graphs?
Mark
Offline TheBreeze
  • Craig
  • Win NT 10.0
    • WDL
« Reply #43 on: April 27, 2018, 02:03:04 PM »
Mark - thank you.   I have set to false and gauges work without generating numerous errors on the server.
I will run this way until or if it can be corrected on my server.
Craig
Offline niko
  • syzygy
  • Global Moderator
  • Win 7/Srvr 2008R2
« Reply #44 on: April 27, 2018, 02:26:51 PM »
Looking good now :thumbright:
