Author Topic: SteelSeries graphs not consistent  (Read 3548 times)
Offline TheBreeze
  • Craig
  • On Lake Ontario, Rochester, N.Y. - Davis VP2 Plus
  • Win NT 10.0
  • Chrome 65.0.3325.181
    • WDL
Re: SteelSeries graphs not consistent
« Reply #15 on: April 23, 2018, 02:03:45 AM »
OK - will try again in the morning.
Lake Ontario Weather  www.cdcpcconsulting.com/Webster_Weather
AMD FX 6300 6 Core with 8 GB Mem, 320Gb Raptor SATA Raid,  NVidia GT 240 PCIe Video, Windows 10 Pro 64 bit dedicated Weather Machine
Running WD 10.37S63 WDL 6.09
Offline mcrossley
  • Wilmslow, Cheshire, UK
    • none
  • Win NT 10.0
  • Chrome 66.0.3359.117
    • WilmslowAstro Weather
« Reply #16 on: April 23, 2018, 04:38:34 PM »
Sorry, but I was pretty sure when I loaded up your test page it didn't show as version 4.2.0 - I went and checked which version I was using before I posted (which is 4.2.0)
Mark
Offline TheBreeze
  • Craig
  • Win NT 10.0
    • WDL
« Reply #17 on: April 26, 2018, 03:39:10 PM »
OK, official frustration... #-o
I redid everything and am getting the same results.  I am using JPgraph-4.2.0 and wxgraphs off broadstairs site dated 11/20/2016.  When the SteelSeries loads, it look fine but the graphs do not resolve consistently, and there are server errors.  See attachment.  If I call directly any graph, it is created and resolves fine.
Errors start with 'cannot allocate memory:couldn't  create child.......
Any thoughts?
Craig
Offline niko
  • syzygy
  • Global Moderator
  • Northern California, U.S.A.
  • Win 7/Srvr 2008R2
« Reply #18 on: April 26, 2018, 03:56:59 PM »
Clutching at straws let's see if there are any php errors, add this line right at the top of one of the graph scripts
error_reporting(E_ALL);
and then run that script
Offline mcrossley
    • none
  • Win NT 10.0
« Reply #19 on: April 26, 2018, 04:00:38 PM »
If niko's suggestion doesn't throw any light on this, then it sounds like the php fpm (if you are using fpm) needs some more memory allocating to it to me.
I set my script memory limit to 128M which I think may be the default in 7.0?...
Code: [Select]
memory_limit = 128M
http://php.net/memory-limit
Mark
Offline niko
  • syzygy
  • Global Moderator
  • Win 7/Srvr 2008R2
« Reply #20 on: April 26, 2018, 04:11:33 PM »
Mark, if you look back at the chart in reply #8 it appears he's hitting a 1 GB limit  :?
Offline mcrossley
    • none
  • Win NT 10.0
« Reply #21 on: April 26, 2018, 04:48:09 PM »
Hmm, 1GB is an awful lot of memory, wonder if it is a shared process on a shared hosting server rather than each client getting their own process.
Mark
Offline TheBreeze
  • Craig
  • Win NT 10.0
    • WDL
« Reply #22 on: April 26, 2018, 04:55:48 PM »
Niko - Mark - put line of code into script and ran it - there were no errors in the server logs and graph resolved properly.
Craig
Offline niko
  • syzygy
  • Global Moderator
  • Win 7/Srvr 2008R2
« Reply #23 on: April 26, 2018, 05:32:16 PM »
Yeah, I think there's something funky on the server side. Many users have installed this graph set over time, in the gauges or standalone, and Craig's the first one that I can recall getting this issue  :(
It would be interesting to see what limits are set in php.ini but I don't know if Craig has access to that.
Offline niko
  • syzygy
  • Global Moderator
  • Win 7/Srvr 2008R2
« Reply #24 on: April 26, 2018, 05:43:55 PM »
Craig
Try running this script:
Code: [Select]
<?php
print_r
(ini_get('memory_limit'));
Offline TheBreeze
  • Craig
  • Win NT 10.0
    • WDL
« Reply #25 on: April 26, 2018, 08:13:10 PM »
Niko -Hope I did this correctly - created a new php file in Dreamweaver and put it on the server and call the file - the return was 256M with no errors.
Craig
Offline niko
  • syzygy
  • Global Moderator
  • Win 7/Srvr 2008R2
« Reply #26 on: April 26, 2018, 08:19:38 PM »
Yep, that's OK. No red flag there unfortunately  :(
Offline TheBreeze
  • Craig
  • Win NT 10.0
    • WDL
« Reply #27 on: April 26, 2018, 08:28:06 PM »
OK - thanks  -  just sent you a PM.
Offline niko
  • syzygy
  • Global Moderator
  • Win 7/Srvr 2008R2
« Reply #28 on: April 26, 2018, 09:19:07 PM »
It's a problem with jpgraph in general, not specific to the wxgraphs. I set up a test page on Craig's server using five of the jpgraph examples and it has the same problem  :?
Offline TheBreeze
  • Craig
  • Win NT 10.0
    • WDL
« Reply #29 on: April 26, 2018, 09:26:49 PM »
Niko - thank you.   I also noticed that they had throttled me back since after numerous tests and attempts with high memory usage, so I think it is a pre-programmed reaction that lasts for maybe 24 hours..
Craig
