No go, sadly. Downloaded new zip and extracted to a new consolewdfiles dir after backing up the old one. I did port over (overwrite) the config.txt, if you modified that and I was supposed to use it.
Apparently, temp and hum are both actually getting the values from the config, as I can see them in the program output lines before the repeated Irox reads and data readings. (I’ve used up to ±10C and ±10 pts. humidity. No luck so far.)
If you have any other ideas, please post. i’m still setting things up and testing, so i’m not “down”. Will watch this thread. Thanks!
