Author Topic: Data output issue using Raspberrypi v3 B+ and ConsoleWD issue 17.3  (Read 4284 times)
  • Davis VP2
  • Chrome 67.0.3396.87
    • Weather Display
Re: Data output issue using Raspberrypi v3 B+ and ConsoleWD issue 17.3
« Reply #75 on: July 06, 2018, 07:56:01 PM »
using my words?
it looks like what you are doing is using the zoom function built into the graphing component
where you can use right mouse click and hold and drag to create a zoomable box area (when you let go)
what is SD1 and SD3?
Offline Redsafety
  • Chrome 67.0.3396.99
« Reply #76 on: July 06, 2018, 07:59:56 PM »
Spot on :)
  • Davis VP2
    • Weather Display
« Reply #77 on: July 06, 2018, 08:59:58 PM »
what is SD1 or SD3?
Offline Redsafety
« Reply #78 on: July 08, 2018, 11:07:21 AM »
As I said in my post of the 6 July, Using the same data set (see this posts attachment) I have attached three screen dumps SD1 was using your original scaling SD2 your new scaling and SD3 zoom mode. As you highlighted correctly in your previous post the reference I made to zoom mode is via the built-in the graphing component.
  • Davis VP2
    • Weather Display
« Reply #79 on: July 08, 2018, 07:35:37 PM »
it was not clear to me that SD meant screen dump
the attachment does not contain any image files
one problem with the box zoom is its not easy to go back to normal zoom level?
