Data output issue using Raspberrypi v3 B+ and ConsoleWD issue 17.3
yes, that is what you should be seeing
and yes, that is the sort of time out values to try, but also try bigger values (e.g 500)
(make sure to restart after making that change and also make sure to check that that value is picked up in the start up messages)
