Author Topic: Data output issue using Raspberrypi v3 B+ and ConsoleWD issue 17.3  (Read 4212 times)
Offline Redsafety
  • Win NT 10.0
  • Chrome 67.0.3396.87
Re: Data output issue using Raspberrypi v3 B+ and ConsoleWD issue 17.3
« Reply #45 on: June 26, 2018, 05:48:42 PM »
Hi Steve
I tried your suggestion but it did not work.
Run the main program, started dpi at 17:41 26/06/18 run it until 18:15 still with the main programming running closed wdpi and then restarted it, however still no chats displayed.
Have attached screen dump and the log file.
Regards
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #46 on: June 26, 2018, 06:38:07 PM »
i have tested here and it works as I have described OK
that screen shot is very small image...hard to make out anything
Offline Redsafety
  • Win NT 10.0
« Reply #47 on: June 26, 2018, 07:01:52 PM »
Screen Dump V2
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #48 on: June 26, 2018, 07:13:31 PM »
I have found one bug that will cause a silent crash and stop the graph from updating
I will get that version uploaded for you
Offline Redsafety
  • Win NT 10.0
« Reply #49 on: June 26, 2018, 07:32:10 PM »
Thank you, just let me know when you have uploaded it
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #50 on: June 26, 2018, 07:58:57 PM »
actually, if you could .zip and email me your data files
last31daysdata.inf and latest.inf and latestindoor.inf
I will test/check here
Offline Redsafety
  • Win NT 10.0
« Reply #51 on: June 26, 2018, 08:32:18 PM »
I have zip'ed the whole folder, cant see the last one you have identified
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #52 on: June 26, 2018, 09:59:05 PM »
i am getting closer to a resolution :)
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #53 on: June 26, 2018, 11:08:56 PM »
try a new update of consolewd for raspberrypi 3 from the download page
new version of wdpi and consolwd (update both)
graph should work for you hopefully
I have still not fixed it not updating at this stage (a restart does though)
Offline Redsafety
  • Win NT 10.0
« Reply #54 on: June 27, 2018, 05:17:55 PM »
Hi Steve
I have downloaded your updated file run consolewdfiles using sudo ./consolewd
once data was being logged I then opened wdpi  no chat were displayed
still keeping consolewd logging data I closed wdpi  then reopened dpi  still no chats were displayed
Repeated this a few times on the last occasion I opened wdpi using the terminal mode, see below for data logged:-
[HINT] TWinControl.CreateWnd creating Handle during loading mainform:Tmainform csDesigning=False
[HINT] TWinControl.CreateWnd creating Handle during loading data_rec:TEdit csDesigning=False
[HINT] TWinControl.CreateWnd creating Handle during loading data_qual:TEdit csDesigning=False
(wdpi:1042): Gdk-CRITICAL **: IA__gdk_drawable_get_size: assertion 'GDK_IS_DRAWABLE (drawable)' failed
ERROR in LCL: TGtk2WidgetSet.StretchCopyArea DestDC=759E05E0 Drawable=nil
Creating gdb catchable error:
  $00134474  TLAZLOGGER__DEBUGLNSTACK,  line 676 of lazloggerbase.pas
  $000DF7AC  DUMPSTACK,  line 1415 of lclproc.pas
  $000DD2B4  RAISEGDBEXCEPTION,  line 860 of lclproc.pas
  $001F2E24  RAISEDESTDRAWABLENIL,  line 4060 of gtk2widgetset.inc
  $001F29A4  TGTK2WIDGETSET__STRETCHCOPYAREA,  line 4123 of gtk2widgetset.inc
  $002114B4  TGTK2WIDGETSET__STRETCHMASKBLT,  line 9489 of gtk2winapi.inc
  $00197B6C  STRETCHMASKBLT,  line 467 of ./include/lclintf.inc
  $00173314  TRASTERIMAGE__DRAW,  line 246 of ./include/rasterimage.inc
  $0017ED90  TCANVAS__STRETCHDRAW,  line 48 of ./include/canvas.inc
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #55 on: June 27, 2018, 06:52:39 PM »
are you using the new version?
1.4
of the WDPI program
Offline Redsafety
  • Win NT 10.0
« Reply #56 on: June 27, 2018, 07:23:03 PM »
Yes WD PI Vers 1.4  it the one in the updated folder I downloaded, I'm running it within the consolewd folder structure
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #57 on: June 27, 2018, 07:57:51 PM »
I suspect those GDK errors are the issue
another way to see the data would be to setup meteotemplate
or
fresh WDL
or similar
Offline Redsafety
  • Win NT 10.0
  • Chrome 67.0.3396.99
« Reply #58 on: June 27, 2018, 09:31:43 PM »
Pleased I was able to provide some useful data
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #59 on: June 27, 2018, 11:01:20 PM »
I do see the graph OK when I run WDPI with the data files you posted
it might be that I have a different version of the GDK library installed (maybe you could look into updating that?)
