Author Topic: Solar Current % reading says Nan%  (Read 841 times)
Offline Weerstation
  • The Netherlands
  • Mozilla compatible
« on: April 08, 2018, 11:15:07 AM »
Sunrise 07:02
Latests WD 10.37S69
I noticed that since March 25, my solar current % reading is displaying Nan% for about 60 to 90 minutes from Sunrise on.
Then suddenly the solar value jumps fast to a higher value from 0.
It is not gradually fading in.
Here is from my April vantagelog file.
1  4 2018  8 27 0.00 0.0 0.0 255.0 100.000
1  4 2018  8 28 9.62 0.0 0.0 255.0 100.000
2  4 2018  8 25 0.00 0.0 0.0 255.0 100.000
2  4 2018  8 26 48.94 0.0 0.0 255.0 100.000
3  4 2018  8 22 0.00 0.0 0.5 255.0 100.000
3  4 2018  8 23 42.77 0.0 0.5 255.0 100.000
4  4 2018  8 20 0.00 0.0 0.0 255.0 100.000
4  4 2018  8 21 85.93 0.0 0.0 255.0 100.000
5  4 2018  8 18 0.00 0.0 0.0 255.0 100.000
5  4 2018  8 19 25.51 0.0 0.0 255.0 100.000
6  4 2018  8 15 0.00 0.0 0.0 255.0 100.000
6  4 2018  8 16 178.05 0.0 0.0 255.0 100.000
7  4 2018  8 13 0.00 0.0 0.0 255.0 100.000
7  4 2018  8 14 110.88 0.0 0.0 255.0 100.000
8  4 2018  8 11 0.00 0.0 0.0 255.0 100.000
8  4 2018  8 12 41.77 0.0 0.0 255.0 100.000
Graphs for solar March 25 and 26
What could be causing this Nan%.
The solar sensor does output 13.4 mV
« Last Edit: April 08, 2018, 09:43:59 PM by Weerstation »
Vantage Vue (Firmware 2.14 EU) - WeatherDisplay 10.37S build 89 - USB Weatherlink IP Data Logger
Windows 10 Home 64-bit - HP Pavilion G7 Intel Core I3 2.4 GHz 4 Gb
Offline niko
  • syzygy
  • Northern California, U.S.A.
  • Win 7/Srvr 2008R2
  • Chrome 65.0.3325.181
Re: Solar Current % reading says Nan%
« Reply #1 on: April 08, 2018, 01:37:37 PM »
Try setting the latitude and longitude to the correct values for your location.
Offline Weerstation
  • The Netherlands
« Reply #2 on: April 08, 2018, 02:38:11 PM »
These are correct.
Offline niko
  • syzygy
  • Win 7/Srvr 2008R2
« Reply #3 on: April 08, 2018, 02:47:06 PM »
Really, you've moved to latitude 1 minute North = the equator?
  • Davis VP2
    • Weather Display
« Reply #4 on: April 08, 2018, 08:17:54 PM »
your screen shot shows no value for the degrees.only values for the minutes?
Offline Weerstation
  • The Netherlands
« Reply #5 on: April 08, 2018, 09:42:39 PM »
My settings for longitude and latitude are correct.
They have been for the past 7 years.
  • Davis VP2
    • Weather Display
« Reply #6 on: April 08, 2018, 10:11:59 PM »
they are not correct according to the screen shot
Offline Martyn
  • Davis VP2+ FARS/solar/UV
  • Bristol, UK
  • Win 7/Srvr 2008R2
  • Firefox 59.0
    • Horfield/Filton, Bristol, UK weather station
« Reply #7 on: April 08, 2018, 10:14:52 PM »
Probably photoshopped out by the OP to avoid giving away his location?
Martyn,
Bristol, UK
Twitter: https://twitter.com/HorfieldWeather
FB: https://www.facebook.com/bristolweather
CWOP: CW2888
WU: IBRISTOL3
  • Davis VP2
    • Weather Display
« Reply #8 on: April 08, 2018, 11:03:19 PM »
goodness me
does make it hard to help then
maybe he has ticked to use high latitude in the sun moon rise/setup?
Offline Weerstation
  • The Netherlands
« Reply #9 on: April 09, 2018, 10:37:49 AM »
he has not ticked to use high latitude in the sun moon rise/setup
Offline Martyn
  • Bristol, UK
  • Win 7/Srvr 2008R2
  • Firefox 59.0
« Reply #10 on: April 09, 2018, 10:44:13 AM »
If you have not changed anything or updated WD on March 25 the only other thing it may possibly be related to is the clocks going forward to daylight savings time on that date.
Martyn,
Bristol, UK
CWOP: CW2888
WU: IBRISTOL3
Offline Weerstation
  • The Netherlands
« Reply #11 on: April 09, 2018, 03:59:13 PM »
Thanks for replying, Martyn.
You might be right about March 25 and Daylight Saving.
I did edit settings.
I had asked about it in another thread.
I may have misunderstood or the info was incorrect, I don't know.
I usually am on GMT+1 and I am east of gmt.(negativ)
At the timezone I have -1.
With Daylight Saving I am on gmt+2
At the timezone I have -2.
These settings may be causing the problem.(See image)
I have "Daylight Saving in use (does auto set) ticked.
Does this mean I don't have to add another hour to the timezone, it stays -1,
with the setting "Do not auto set time zone" ticked.
Offline Martyn
  • Bristol, UK
  • Win 7/Srvr 2008R2
  • Firefox 59.0
« Reply #12 on: April 09, 2018, 04:12:26 PM »
That box has always been ticked in my setup and I never manually change the hour in the timezone box, but I don't know how it works for timezones away from GMT (0).
Martyn,
Bristol, UK
CWOP: CW2888
WU: IBRISTOL3
  • Davis VP2
    • Weather Display
« Reply #13 on: April 09, 2018, 08:37:00 PM »
@Weerstation
what weather station type?
and what type of solar sensor?
also do you actually see the word Nan?
Offline Weerstation
  • The Netherlands
« Reply #14 on: April 10, 2018, 05:02:45 AM »
Davis Vantage Vue
Hobbyboards
Yes
« Last Edit: April 10, 2018, 05:04:40 AM by Weerstation »
