so…nearly all is running now.
Except of the rainfall data.
i have a WH1080 - and it shows me from wdconsole 10-52 inches rain today, 52 inches for the months
and today its the first day in April with rain…
and is there a how2 how i can stat wdconsole at startup?
Weather station type=166 // Irox=59,WMR100=232,WMR200=233,WMR300=235,WMR968=8,WMR918=3,WM918=1,Davis VP=31,Davis WMMII=4, WH1081=166,2310=60,WXT510=190,3600=61,Davis IP=32, OWWfile=71,universal=34,102=meteobridge,weatherflow=72
meteobridge username=
meteobridge IP=192.168.0.1
meteobridge password=
latitude= 50.765 /// latitude, e.g -38.375 for southern hemisphere
longitude= 6.722 /// e.g -17idwow5.456 for east of UTC/London
Station name=Wetter Erp
Start up daily rain(mm)=0.0
Start up monthly rain(mm)=0.0
Start up yearly rain(mm)=0.0
Do wunderground=Y //For updating wunderground.com (set to Y for yes, N for no) (every 5 minutes)
Wunderground username=INORDRHE202
timezone= (to change the local PC hour used)offset
Direction offset (whole degrees)=0
Barometer offset(hpa)=0
Do clientraw FTP=Y //(set to Y for yes, N for no), uploads every 1 minute
Save logfile=Y //to save the .txt logfile (set to N to save on disk space)
Logfile metric=Yidwow
Create custom file=Y //converts the custom tags in a file called wxlocal.html to wx.html
Use this filename instead of wx.html=testtags.php
Use this filename instead of wx2.html=
Use this filename instead of wx3.html=
Use this filename instead of wx4.html=
Use this filename instead of wx5.html=
FTP the custom file=Y //will FTP the wx.html or filename you set to FTP server specified (clientraw FTP needs to be enabled too)
Units for custom tag file output:
Temp in celsius=Y
Wind in=kph // options are: mph,kts,kph,m/s (changes the custom tags)
Baro in metric=Y
Rain in metric=Y
run cron files=Y // set to N to not run the separate cron files
do custom log=N // set to Y to create an appended logfile from a template (customlog.txt)
custom log out=customlogout.txt
temp offset= //C
hum offset=
wmr300 channel number=1
Rain Offset=0.0 //mm
Modified rain gauge=
universalupdaterate=2
