So is weather display live dead? I don’t see a place to download that, is it now Fresh Weather Display Live? When I try to run WDLive I get a Serial Number Error…
I think that you will have to do a search on the forum about it, my weather display live is still working here but you may have to allow flash to work in your browser.
If you want the original Flash WDL the download is now here. You can contact Brian to buy a license. The world has turned against Flash and Fresh Weather Display Live is a free/donationware replacement that uses javascript instead.
If you want a page like your example which uses AJAX to re-write the data your best bet is to use a template such as the one supported by Ken True at https://saratoga-weather.org/index.php
just email me the url needed and I will you email you a code for WDL
flash is not very well supported now, hence other alternatives like freshwdl and steel gauges
