OW-ENV-TP temperature/Barometric Pressure Support
Will Weather Display support the EDS OW-ENV-TP SENSOR?
link to any info?
https://www.embeddeddatasystems.com/OW-ENV--Environmental-Sensors_p_172.html
This a link to the web site using 1-wire to connect to sensor.
I do have support for 1 wire barometer already
does it show up via that at all?
I get bad readings, but it does show up on the main screen!
OW-ENV-TP is listed, what station type do I select. The One wire viewer shows the ROM number, no data is displayed in Wdisplay.
have you tried with the WD hobby boards 1 wire reader program?
Yes and I did see the data, now I need it to show up in Wdisplay.
In Wdisplay how do I setup so it shows up on the main screen and in the data log files.
and so the data is correct?
have you ticked enabled, in the WD hobby boards 1 wire reader program etc?
what is your weather station type you have selected in WD?
the more info you can provide, the better
Trying to screen shot the hobby-boards reader to get the data that is showing up.
Attached to this reply is the one wire data from HB.
This data does not show up in WD. My weather station choice is Dallas 1-wire.
