Hello,
Is there a way to adjust this chart?
As you can see in the picture, the average temperature is below the chart.
Hi Matrix
No it is not … you are looking at a 3d chart with the apparent “zero” actually towards the rear right hand side…
you may have to re adjust your eyes to see it properly…
cheers
that chart should be able to go below zero
which chart is it exactly? (i.e which tab)
I would need your data files to be able to duplicate
Yes, the chart is not able to show below zero.
Are you sure about data files and where are they?
not sure why you are asking me that question
I would need a copy of your data files to be able to duplicate/fix the issue here
which exact graph is this?
I can not find the chart data file.
Is it in the datafiles folder?
There is a charttemp.tee file there.
what I need is or you to .zip and email me your WD data files
the monthxxxxx.inf data files
if you had saved a configuration of that graph then try deleting the .tee file
He sent the entire setup wd to email
Brian, it’s settled.
I deleted the tee file.
has restarted wd and it’s all right.
Thanks for your cooperation
OK, i thought it was likely it was the .tee file
you do not need to email me the data files now
