Author Topic: LED Sign w/Ethernet or Wireless IP Feed?  (Read 1187 times)
Offline Breezy
  • Indian Trail Weather
  • Hessville, NY, U.S.A.
    • baldwinj1
  • Win 7/Srvr 2008R2
  • Firefox 58.0
« on: March 12, 2018, 03:31:26 PM »
Brian,
8-10 years ago you designed a program to send WD (tags) weather data using a "serial" connection to a "Betabrite" led sign. Newer outdoor led signs are now
using Ethernet cables or wireless IP sources to feed the signs. Can WD be programmed to use Ethernet or wireless IP? If so, what specific "sign", "connectivity" information is required to design a program?
Cheers,
Jeff
W7-64, Intel Z170A 16 GB RAM
Davis VP2 Plus & Soil Moisture/Temp Sensors, Laser Snow Sensor LR4/Fluke 414D, 6 Webcams
  • Davis VP2
  • New Zealand
  • Win NT 10.0
  • Chrome 64.0.3282.186
    • Weather Display
Re: LED Sign w/Ethernet or Wireless IP Feed?
« Reply #1 on: March 12, 2018, 04:25:37 PM »
don't know sorry
if it has data protocol info then I am sure I could add support
Offline Breezy
    • baldwinj1
  • Win 7/Srvr 2008R2
  • Firefox 58.0
« Reply #2 on: March 13, 2018, 04:28:22 PM »
Here are some links for the Alpha data protocol. General link  http://support.adaptivedisplays.com/Documentation/questions.php?questionid=149
Specific link for the StreetSmart 17mm sign  http://support.adaptivedisplays.com/Documentation/categories.php?categoryid=59
I will not have the sign for testing until late April but perhaps you can check into your "current option" in "Setup", "Advanced/Miscellaneous", "LED Sign" to see if
your current LED sign page design meets the attached data protocol.  I plan on using a wireless Ethernet communication option.
I would like to be able to send to the sign various WD "testtags", "%xxxxx%, to be displayed on the sign and also any NWS weather alerts (warnings, watches, advisories) for the specific county where I reside.
Much appreciated!
Cheers ...
Jeff
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #3 on: March 13, 2018, 07:59:56 PM »
I see there is a demo test program (which compiled OK)
Offline Breezy
    • baldwinj1
  • Win 7/Srvr 2008R2
  • Firefox 58.0
« Reply #4 on: March 13, 2018, 08:22:55 PM »
That sounds like a good start. Do you think that your current "LED Sign" program will function with this sign "as is"? To broadcast NWS alerts (warnings, watches, advisories) for my county will I need to do a customization? Your program requires a connection to a serial port in the PC. Would I have to convert from serial to Ethernet wireless with an adapter?
« Last Edit: March 13, 2018, 08:34:59 PM by Breezy »
Jeff
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #5 on: March 13, 2018, 09:52:04 PM »
the data protocol is similar but I do not think compatible?
the sample program does have option to use com port or IP
Offline Breezy
    • baldwinj1
  • Win 7/Srvr 2008R2
  • Firefox 58.0
« Reply #6 on: March 13, 2018, 10:07:51 PM »
Not being compatible could be an issue. I want this sign to be a "public service" to the traffic passing by my location. Being able to alert the public to NWS alerts is a main
consideration for installing the sign. Not all led signs have the flexibility to customize output from other software. I don't want to expend funds on a sign that can not
accept data from other software. I was hoping that this particular sign might work.
What are your suggestions?
Jeff
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #7 on: March 13, 2018, 10:12:34 PM »
what I mean is its not going to work with WD out of the box
and instead I would need to add code to support it
Offline Breezy
    • baldwinj1
  • Win 7/Srvr 2008R2
  • Firefox 58.0
« Reply #8 on: March 13, 2018, 10:17:56 PM »
That's encouraging ... I'm experimenting with your "email weather alert warning section" now. Hopefully it can be integrated into the led sign project.
Jeff
