Author Topic: March report creation?  (Read 258 times)
Offline garyghj
  • MillbankPWS
  • Munlochy Scotland
  • Win NT 10.0
  • Chrome 64.0.3282.186
    • Munlochy weather
« on: March 09, 2018, 07:48:15 PM »
Hi and good evening.
I have encountered a small issue I cannot find the control for. The March2018.htm stopped updating in the webfiles folder 3 days ago. I can see the daily records are up to date in the various tabs under View > Averages/Extremes/Reports. Is there a file creation button or switch I have accidentally turned off? Any advice would be very welcome. Thank you. G
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
Re: March report creation?
« Reply #1 on: March 10, 2018, 03:40:54 PM »
what version/build?
Offline garyghj
  • MillbankPWS
  • Munlochy Scotland
  • Win NT 10.0
    • Munlochy weather
« Reply #2 on: March 10, 2018, 06:42:09 PM »
Hi Brian.
The version is 10.37S and the build is 57.
My PC is an always on machine, but failing to find a solution I restarted the pc and software and the Monthly report became active again, however I have lost two days the 7th and the 8th. Is there any way to recover these as they still appear in Average/Extreme Reports for March as well as the NOAA style reports.
Thank you.
Gary
Offline Weerstation
  • The Netherlands
  • Win NT 10.0
  • Mozilla compatible
« Reply #3 on: March 10, 2018, 11:47:57 PM »
Go to
View
Averages/Extremes/NOAA Style Reports
[Tab] Recreate The Web Av/Ext Page
Set month to 3 for March
Reset the web page averages/extreme
Done
Your new March2018.htm is in your webfiles folder.
The webfiles folder can be found where you installed weatherdisplay.
You have to manually upload March2018.htm
Vantage Vue (Firmware 2.14 EU) - WeatherDisplay 10.37S build 72 - USB Weatherlink IP Data Logger
Windows 10 Home 64-bit - HP Pavilion G7 Intel Core I3 2.4 GHz 4 Gb
Offline garyghj
  • MillbankPWS
  • Munlochy Scotland
  • Win NT 10.0
    • Munlochy weather
« Reply #4 on: March 11, 2018, 12:09:03 AM »
Thank you, but tried this 3 times and still missing 2 days. Incidentally, it took 3 times clicking Reset the web page average/extremes for the blue bar to reach 100%
Offline Weerstation
  • The Netherlands
  • Win NT 10.0
« Reply #5 on: March 11, 2018, 12:35:09 AM »
Have you tried converting the logfile first.
Action
Convert logfile to datafile
Set 32018lg.txt
Convert
Then repeat steps post above.
Still nothing, check the days in your logfile if they begin and end like this.
Check if first and last 10 minutes are present.
Code: [Select]
7  3 2018  0  0 06.6  84 04.1 991.0 0.7 0.9  80 0.0 0.0 7.6 120.4 6.6
 7  3 2018  0  1 06.6  84 04.1 991.1 0.3 0.9  78 0.0 0.0 7.6 120.4 6.6
 7  3 2018  0  2 06.6  84 04.1 991.1 0.2 0.9  84 0.0 0.0 7.6 120.4 6.6
 7  3 2018  0  3 06.6  84 04.1 991.1 0.4 1.7  74 0.0 0.0 7.6 120.4 6.6
 7  3 2018  0  4 06.6  84 04.1 991.1 1.1 2.6  85 0.0 0.0 7.6 120.4 6.6
 7  3 2018  0  5 06.6  84 04.1 991.1 1.0 0.9 123 0.0 0.0 7.6 120.4 6.6
 7  3 2018  0  6 06.7  84 04.2 991.1 0.4 0.9  52 0.0 0.0 7.6 120.4 6.7
 7  3 2018  0  7 06.7  84 04.2 991.1 0.3 0.9  72 0.0 0.0 7.6 120.4 6.7
 7  3 2018  0  8 06.7  84 04.1 991.1 0.2 1.7  66 0.0 0.0 7.6 120.4 6.7
 7  3 2018  0  9 06.7  84 04.2 991.1 0.8 1.7  80 0.0 0.0 7.6 120.4 6.7
 7  3 2018  0 10 06.7  84 04.2 991.1 0.7 2.6  78 0.0 0.0 7.6 120.4 6.7
Code: [Select]
7  3 2018 23 50 04.6  92 03.4 997.4 2.6 7.0 253 0.0 0.0 7.6 120.4 4.6
 7  3 2018 23 51 04.6  92 03.4 997.4 4.2 7.0 225 0.0 0.0 7.6 120.4 4.6
 7  3 2018 23 52 04.6  92 03.4 997.5 3.4 7.0 237 0.0 0.0 7.6 120.4 4.6
 7  3 2018 23 53 04.6  92 03.4 997.4 3.4 6.1 225 0.0 0.0 7.6 120.4 4.6
 7  3 2018 23 54 04.6  93 03.5 997.4 3.6 5.2 212 0.0 0.0 7.6 120.4 4.6
 7  3 2018 23 55 04.6  93 03.5 997.4 3.1 6.1 225 0.0 0.0 7.6 120.4 4.6
 7  3 2018 23 56 04.6  92 03.4 997.4 3.0 6.1 222 0.0 0.0 7.6 120.4 4.6
 7  3 2018 23 57 04.6  92 03.4 997.4 2.6 5.2 215 0.0 0.0 7.6 120.4 4.6
 7  3 2018 23 58 04.5  92 03.4 997.4 2.8 5.2 222 0.0 0.0 7.6 120.4 4.5
 7  3 2018 23 59 04.5  92 03.3 997.4 3.6 7.0 258 0.0 0.0 7.6 120.4 4.5
Offline garyghj
  • MillbankPWS
  • Munlochy Scotland
  • Win NT 10.0
    • Munlochy weather
« Reply #6 on: March 11, 2018, 07:22:53 AM »
Thank you again for your suggestions.
Not sure what this/I have done though as Average/Extremes now show days 23, 24, 25, 26 and 27 March!!
Day 7 is definitely missing from NOAA style reports as well as well as Local Climatological Data.
The log file looks ok for both days, 7 and 8.
Days 7 and 8 missing from Monthly Report.
Please see attached.
Thank's again
Offline hcorrin
  • Ballaugh Isle of Man GB
  • Win NT 10.0
    • Ballaugh Weather
« Reply #7 on: March 11, 2018, 11:47:57 AM »
check the log file around the same times you posted for the 7th and 8th but for 6th and 7th instead
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #8 on: March 11, 2018, 08:56:15 PM »
.zip and email me the logfile, and I will test/check here
