RPi and mysql 5.6
I want to run ConsoleWD 14 on a RPi3 with raspbian jessi or stretch, but I can not install mysql client 5.6. There is not available release of the mysql 5.6+ for arm.
For jessi you can install 5.5.99 (latest mysql release for arm) and for stretch you can install MariaDB 10…
how I can solve this error?
TMySQL56Connection can not work with the installed MySQL client version: Expected (5.6)
I am sure there are others who were able to install it (which is why its expecting that version)
Very strange, according to the wisdom of the intermet, this does appear to be true:
I have tried to install through MySQL APT repository.
You can install deb package which add official repositories of mysql.
https://dev.mysql.com/downloads/repo/apt/
But when you do apt-get update, you can see warnings about mysql does not support armhf architecture.
I am still trying to install mysql-client-5.6.
Now, I have installed Ubuntu 14.04 in the RPi as there is amrhf package of mysql-5.6.
But it depends of 5.5.99 packages… Although you install manually every package always has some required dependency to 5.5.X.
mysql-apt-config/now 0.8.9-1 all [installed,local]
mysql-client-5.6/trusty-updates,trusty-security,now 5.6.33-0ubuntu0.14.04.1 armhf [installed]
mysql-client-core-5.6/trusty-updates,trusty-security,now 5.6.33-0ubuntu0.14.04.1 armhf [installed]
mysql-common/trusty-updates,trusty-security,now 5.5.59-0ubuntu0.14.04.1 all [installed,automatic]
mysql-common-5.6/trusty-updates,trusty-security,now 5.6.33-0ubuntu0.14.04.1 all [installed]
Really someone has WD14 on a RPi using mysql option?
At last, I have running WD17 with the RPi.
Ubuntu 14.04 armhf and the specific .deb mysql-client-5.6 installed manually.
We have some dependencies breach, but it works.
There are several troubles (I don’t kown if it is the specific version or system configuration):
-I can`t use extra table columns that I had. I can in the WD windows version.
 Error executing query: Column count doesn't match value count at row 1
 could not write INSERT IGNORE INTO xxxxxxx VALUES ('WMR200-08:35:25','2018/03/09','08:35:00','5.1','248','9','11.2','77','988.3','0.0','0.0','0.0','0.000','0.000','22.0','45','0.0','0','0.0','0','0','0.0','0.0','0.0','0.0','0.0','0.0','0.0','0','0','0','08','35','25','WMR200-08:35:25','0','0','09','03','0','0','0','0','0','0','0','11.2','11.4','15.2','10.9','0','Dry','-24.7','15.0','7.3','1601.0','16.7','8.9','15.2','10.9','0.0','15.2','10.9','11.2','13.0','2018')
into meteoalmansa
Could not write data into xxxxxxxx
-consolewd ignores this configured config.txt params:
 Mysql time=60
  Start up daily rain(mm)=0
  Start up monthly rain(mm)=0.3
  Start up yearly rain(mm)=61.7
-Sometimes temperature captured from usb by the consolewd is different of the wmr200 display. For example, once I have can seen 10.3
yes, consolewd mysql only uses the default table data, does not allow any customisation (currently)
I thought i had fixed the rain totals from the config.txt
try setting those in the ini file instead?
How big a deal would it be to switch to MariaDB which seems to be replacing MySQL?
I learned that in MariaDB 10.2 the version command allows you to spoof the version string so that it will work with apps expecting MySQL. MariaDB is fully compatible with MySQL so this would seem to be a better option for RPi users.
