My 24 hour graphs don’t show any data as of lately.
I am trying to rebuild those going to View/Graph History.
After setting date and loading, the winddir graph holds no data. See attachment.
Is this the right place to rebuild those graphs?
I noticed the time axis runs from 00 to 02, is this correct. Shouldn’t this be from 00 to 00 next day.
What can be done about the winddir data not displaying in the graph.
TIA
Thought my problem had been solved by updating to the latest S67 version.
my curr24hourgraph.gif, 48hourgraph.gif and 72hourgraph.gif are fine.
Did I mis a setting here or there, why is the datestamped graph not created.
Once this problem is solved, I’d like to know how to create earlier datestamped graphs.
Don’t want to make thinks complicated. :oops:
TIA
that date stamped graph is created from the WD daily logfile
is that being updated OK?
also you can fix the wind direction graph being wider like that too
Daily logfile.
dailylog.txt you mean?
Just checked and last entry was recent.
Sorry, don’t understand what you mean by that.
the wind direction graph extends wider than the other graphs
there is a fix for that
also is your normal WD logfile up to date? (52018lg.txt)
Yes, wd logfile is up to date.
Didn’t know about that fix. Thanks.
For those who don’t know about that fix.
http://discourse.weather-watch.com/p/476621
it only affected people who had a very early version of WD
re the graph not updating
any error in WD under view, program event log?
From the attached the month and day values are the wrong way round you have day 2 and month 19
You are absolutely right. I get back on that.
But still no data for March 5.
The fix worked as you can see, graph is smaller now.
And I rearranged the titles above the graph a bit.
Didn’t know how to do that but learned fromm the other thread about these graphs.
March 5
when you say no data for march 5
do you mean for that date stamped graph file?
does that day show up OK under view, av/ext?
what if you go to view, graph history, then select that day?
Yes, no data in the datestamped graph 20180305.gif, see post above.
20180306.gif same thing no data in it.
Day 5 and 6 show up in view, av/ext just fine.
Attachment shows day 5 selected in graph history.
Of later concern, see the solar data in yellow, it is way off in time.
It shows from 16:00 until around midnight, it’s dark here then. #-o
One more thing.
I have ticked the setting to not plot the indoortemp.
Although there is no line for indoortemp, the title indoortemp is above the graph.
Strange!
Just noticed that 20180306.gif in my webfiles folder got updated with the same data in it as in the attachment from post above which was day 5, not day 6.
There wasn’t any data in 20180306.gif before.(No lines in the graphs)
The file 20180506.gif was created 04:23 when I selected day 5 in View/Graph history.
The jpg for the attachment I created at 04:29
#-o
have you tried converting the logfile to data file?
can you .zip and email me your logfile?
