Author Topic: How to recreate 24 hour graph (20180219.gif). No data in graph.  (Read 386 times)
Offline Weerstation
  • The Netherlands
  • Win NT 10.0
  • Mozilla compatible
My 24 hour graphs don't show any data as of lately.
I am trying to rebuild those going to View/Graph History.
After setting date and loading, the winddir graph holds no data. See attachment.
Is this the right place to rebuild those graphs?
I noticed the time axis runs from 00 to 02, is this correct. Shouldn't this be from 00 to 00 next day.
What can be done about the winddir data not displaying in the graph.
TIA
« Last Edit: March 05, 2018, 08:44:37 PM by Weerstation »
Vantage Vue (Firmware 2.14 EU) - WeatherDisplay 10.37S build 72 - USB Weatherlink IP Data Logger
Windows 10 Home 64-bit - HP Pavilion G7 Intel Core I3 2.4 GHz 4 Gb
Offline Weerstation
  • The Netherlands
  • Win NT 10.0
Thought my problem had been solved by updating to the latest S67 version.
my curr24hourgraph.gif, 48hourgraph.gif and 72hourgraph.gif are fine.
Did I mis a setting here or there, why is the datestamped graph not created.
Once this problem is solved, I'd like to know how to create earlier datestamped graphs.
Don't want to make thinks complicated.  :oops:
TIA
  • Davis VP2
  • New Zealand
  • Win NT 10.0
  • Chrome 64.0.3282.167
    • Weather Display
that date stamped graph is created from the WD daily  logfile
is that being updated OK?
also you can fix the wind direction graph being wider like that too
Offline Weerstation
  • The Netherlands
  • Win NT 10.0
Daily logfile.
dailylog.txt you mean?
Just checked and last entry was recent.
Offline Weerstation
  • The Netherlands
  • Win NT 10.0
Sorry, don't understand what you mean by that.
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
the wind direction graph extends wider than the other graphs
there is a fix for that
also is your normal WD logfile up to date? (52018lg.txt)
Offline Weerstation
  • The Netherlands
  • Win NT 10.0
Yes, wd logfile is up to date.
Didn't know about that fix. Thanks.
For those who don't know about that fix.
https://www.weather-watch.com/smf/index.php/topic,61696.msg493471.html#msg493471
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
Re: How to recreate 24 hour graph (20180219.gif). No data in graph.
« Reply #7 on: March 05, 2018, 09:03:27 PM »
it only affected people who had a very early version of WD
re the graph not updating
any error in WD under view, program event log?
Offline Weerstation
  • The Netherlands
  • Win NT 10.0
« Reply #8 on: March 05, 2018, 09:13:18 PM »
No errors.
Offline hcorrin
  • Ballaugh Isle of Man GB
  • Win NT 10.0
    • Ballaugh Weather
« Reply #9 on: March 05, 2018, 10:31:57 PM »
From the attached the month and day values are the wrong way round you have day 2 and month 19
Offline Weerstation
  • The Netherlands
  • Win NT 10.0
« Reply #10 on: March 06, 2018, 06:34:58 AM »
You are absolutely right. I get back on that.
But still no data for March 5.
The fix worked as you can see, graph is smaller now.
And I rearranged the titles above the graph a bit.
Didn't know how to do that but learned fromm the other thread about these graphs.
March 5
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #11 on: March 07, 2018, 12:44:00 AM »
when you say no data for march 5
do you mean for that date stamped graph file?
does that day show up OK under view, av/ext?
what if you go to view, graph history, then select that day?
Offline Weerstation
  • The Netherlands
  • Win NT 10.0
« Reply #12 on: March 07, 2018, 03:45:39 AM »
Yes, no data in the datestamped graph 20180305.gif, see post above.
20180306.gif same thing no data in it.
Day 5 and 6 show up in view, av/ext just fine.
Attachment shows day 5 selected in graph history.
Of later concern, see the solar data in yellow, it is way off in time.
It shows from 16:00 until around midnight, it's dark here then. #-o
One more thing.
I have ticked the setting to not plot the indoortemp.
Although there is no line for indoortemp, the title indoortemp is above the graph.
« Last Edit: March 07, 2018, 03:52:09 AM by Weerstation »
Offline Weerstation
  • The Netherlands
  • Win NT 10.0
« Reply #13 on: March 07, 2018, 04:13:15 AM »
Strange!
Just noticed that 20180306.gif in my webfiles folder got updated with the same data in it as in the attachment from post above which was day 5, not day 6.
There wasn't any data in 20180306.gif before.(No lines in the graphs)
The file 20180506.gif was created 04:23 when I selected day 5 in View/Graph history.
The jpg for the attachment I created at 04:29
 #-o
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #14 on: March 07, 2018, 06:40:50 PM »
have you tried converting the logfile to data file?
can you .zip and email me your logfile?
