NWS Five Day Forecast Failing
Tried to search for the topic here and didn’t see this brought up? A person viewing my site just noticed the NWS 5 day forecast section, was missing. Now it says “NWS Weather Forecast - Outlook &”
My site has some information for one day and Chris who helps me out has nothing in his similar area of the page.
You can see the issue at http://weatherriorancho.com/
Sorry if I missed a previous discussion on this issue.
Lew
Yesterday, the NWS site forecast.weather.gov and www.weather.gov switched to https only.
Your advforecast2.php script V4.00 - 06-Jul-2015 will no longer work as it is http only.
Update to either advforecast2.php V4.03 (page scraper version) or V5.05 (JSON version) to fix the issue.
I don’t see the check-fetch-times.php utility on your site … using it with ?show=versions would show you what scripts need updates.
Download a copy from here then it will show you what updates you need.
Hi Ken, so happy to hear from you…
Since I am running the Burnsville version, will any of these updates affect what I am running other than the one you said I really need? Speaking of which, is there a somewhat easy want to get back to the “True” version as I haven’t seen an update in years and his own site isn’t even up?
The list of outdated files is huge…
Script
Origin Script
Name Installed Script
Version Status Release Script
Version Installed Script
Version Installed Script Internal
Version Description
USA advforecast2.php Need update to
V4.02 - 2015-11-07 V4.02 - 2015-11-07 V4.00 - 2015-07-06 advforecast2.php (multi) - V4.00 - 06-Jul-2015
Common ajax-dashboard.php Need update to
V1.26 - 2013-01-12 V1.26 - 2013-01-12 V1.00 - 2011-01-15 1.00 - 15-Jan-2011 on 15 January 2011 23:05 EST
Common ajax-gizmo.php Need update to
V1.14 - 2013-03-17 V1.14 - 2013-03-17 V1.09 - 2011-03-23 ajax-gizmo.php V1.09 - 23-Mar-2011 - Multilingual
WD-plugin ajaxWDwx.js Need update to
V2.24 - 2011-12-13 V2.24 - 2011-12-13 V1.00 - 2011-01-15 1.00 - 15-Jan-2011 on 15 January 2011 23:05 EST
USA atom-advisory.php Need update to
V2.12 - 2016-07-15 V2.12 - 2016-07-15 V2.11 - 2016-06-14 atom-advisory.php - V2.11 14-Jun-2016
USA atom-top-warning.php Need update to
V2.10 - 2016-07-15 V2.10 - 2016-07-15 V2.09 - 2016-06-14 atom-top-warning.php V2.09 - 14-Jun-2016
Common check-fetch-times.php Installed version is more recent V1.15 - 2016-10-31 V1.21 - 2018-02-28 check-fetch-times.php Version 1.21 - 28-Feb-2018
Common common.php Current V1.09 - 2015-08-17 V1.09 - 2015-08-17 common.php - Version 1.09 - 17-Aug-2015
USA DualImage.php Current V1.00 - 2015-07-06 V1.00 - 2015-07-06 1.00 - 06-Jul-2015 - initial release
USA floatTop.js Current Vn/a - 2008-03-18 Vn/a - n/a (not specified)
Common flyout-menu.php Need update to
V1.08 - 2013-02-05 V1.08 - 2013-02-05 V1.07 - 2011-03-04 flyout-menu.php (ML) Version 1.07 - 04-Mar-2011
Common get-metar-conditions-inc.php Need update to
V1.14 - 2016-05-23 V1.14 - 2016-05-23 V1.00 - 2011-01-21 get-metar-conditions-inc.php - Version 1.00 - 21-Jan-2011
USA get-nnvl-iod.php Need update to
V2.02 - 2017-01-06 V2.02 - 2017-01-06 V1.09 - 2011-03-05 1.09 - 05-Mar-2011 - replaced split() with explode()
Common get-USNO-sunmoon.php Need update to
V2.04 - 2015-11-11 V2.04 - 2015-11-11 V1.01 - 2011-03-23 get-USNO-sunmoon.php - Version 1.01 - 23-Mar-2011
Common get-UV-forecast-inc.php Need update to
V1.07 - 2012-03-30 V1.07 - 2012-03-30 V1.06 - 2011-02-18 get-UV-forecast-inc.php V1.06 - 18-Feb-2011
USA GR3-radar-inc.php Need update to
V1.05 - 2015-08-12 V1.05 - 2015-08-12 V1.01 - 2008-05-13 1.01 - 13-May-2008 - http://saratoga-weather.org/scripts.php
Common include-metar-display.php File not installed V1.06 - 2011-11-29 include-metar-display.php file not found.
Common include-style-switcher.php Need update to
V1.19 - 2013-02-05 V1.19 - 2013-02-05 V1.18 - 2011-02-10 1.18 - 10-Feb-2011 - fix duplicate id= in wide/narrow selection HTML
WD-plugin include-wxhistory.php Need update to
V1.10 - 2015-08-12 V1.10 - 2015-08-12 V1.05 - 2008-06-30 1.05 30-Jun-2008 – adapted for WD-World-ML template multilanguage use
Common include-wxstatus.php File not installed V1.05 - 2014-07-20 include-wxstatus.php file not found.
USA nws-alertmap.js File not installed Vn/a - 2012-07-28 nws-alertmap.js file not found.
USA nws-alerts-details-inc.php File not installed V1.04 - 2016-08-03 nws-alerts-details-inc.php file not found.
USA nws-alerts-summary-inc.php File not installed V1.01 - 2016-08-03 nws-alerts-summary-inc.php file not found.
USA nws-alerts.php File not installed V1.37 - 2016-08-03 nws-alerts.php file not found.
USA nws-shapefile.txt File not installed Vn/a - 2016-08-03 nws-shapefile.txt file not found.
Common plaintext-parser-data.txt Current V1.06 - 2011-01-01 V1.06 - 2011-01-01 1.06 - 01-Jan-2011
Common plaintext-parser.php Need update to
V1.30 - 2013-12-30 V1.30 - 2013-12-30 V1.26 - 2011-02-22 plaintext-parser.php Version 1.26 - 22-Feb-2011
USA quake-json.js File not installed V1.01 - 2016-08-07 quake-json.js file not found.
USA quake-json.php File not installed V1.12 - 2017-02-21 quake-json.php file not found.
USA radar-status.php Need update to
V1.15 - 2017-02-22 V1.15 - 2017-02-22 V1.06 - 2011-01-26 radar-status.php V1.06 26-Jan-2011
USA swfobject.js Current Vn/a - 2008-03-12 Vn/a - n/a (not specified)
Common thermometer.php Need update to
V1.14 - 2014-07-26 V1.14 - 2014-07-26 V1.07 - 2011-04-02 1.07 - 02-Apr-2011 - fixed WLrealtime offsets for WeatherLink
WD-plugin WD-trends-inc.php Need update to
V1.06 - 2012-02-18 V1.06 - 2012-02-18 V1.04 - 2008-06-25 1.04 - 25-Jun-2008 - now uses testtags.php for data + translation features added
USA WU-radar-inc.php Need update to
V1.13 - 2017-02-21 V1.13 - 2017-02-21 V1.06 - 2011-04-15 1.06 - 15-Apr-2011 - http://saratoga-weather.org/scripts.php
Common wxgraphs.php Need update to
V1.04 - 2013-02-16 V1.04 - 2013-02-16 Vn/a - n/a (not specified)
Common wxmetar.php File not installed V1.01 - 2011-11-27 wxmetar.php file not found.
Common wxquake.php Need update to
V1.06 - 2016-02-14 V1.06 - 2016-02-14 Vn/a - n/a (not specified)
The only two I’d worry about are ajax-dashboard.php and ajaxWDwx.js on your site.
I’d suggest you copy them ajax-dashboard.php → ajax-dashboard6.php and ajaxWDwx.js → ajaxWDwx3.js and upload those files to your site.
Then change Settings-weather.php to have
$SITE['ajaxScript']     = 'ajaxWDwx3.js';  // for AJAX enabled display
and
$SITE['ajaxDashboard'] = './ajax-dashboard6.php';
and upload your Settings-weather.php file.
That sets your site up to be ready to replace ajax-dashboard.php and ajaxWDwx.js with the stock versions while you continue to run the Burnsville versions without update interference.
The rest of the updates are all recommended to install and have been tested up to PHP 7.2 (which I’m currently running).
You are so awesome…thanks for the detailed explanation and everything I need to do. I need a few minutes of time and I have to screw my courage to the wall, and give it a shot. I haven’t heard back from Chris who has the same issue.
Thanks somuch! :smiley:
