Brian,
In Control Panel — Web Files/Web Page Setup --Upload Times. When you select the upload every 5 minutes option. 5 minutes past every hour is missing. Is that normal or no? Thank you.
Brian,
sounds like a bug
but its better to use the customise internet and file creation setup
there you can set times to create and upload for each file
also if you use the upload times in the ftp/internet setup instead, then this bug does not occur
Maybe it is my WD that is the problem. I restarted WD and now the times are back.
My Windows (10 Pro) performed an update last week, restarted my PC and messed up a few of my weather programs including WD. Dang Windows!!
Maybe I need to uninstall everything,reinstall WD and reload the data?
