is this a new install, or?
and is this with the latest version, or?
New install and the latest 9th february version.
Also the same result in Ubuntu 17.10
I just tested here
no settings etc (i.e I deleted the folder wdisplay in the documents folder) and it starts up OK
Well, I tried in /home/user/Documents/wdisplay and in /home/user/wdisplay with no result
Someone said to me that Linux was less problematic than Windows… just to configure or doing anything I have to google the problem because there’s often a problem … #-o
Bad Luck
Thanks anyway
what I can do is add some debug code to try and narrow down where the problem is
question
how much memory on the linux pc?
8 GB RAM
Ok. Ask me for whatever you need
you could try this version as a test
http://www.weather-display.com/downloadfiles/weatherdisplaytest.tar.gz
extract to where you have WD installed already
Copy & Paste the file in WD folder. Same result but it stops loading when Loading energy is in the startup progress bar.
Is it made a log in any place ?
ok, so that means the actual error is occuring on the final running and the loading of the last module was a red herring
question:
where you are running the program from?
i am thinking it might be some permissions problem
I think so but… I’ve installed folder in /home/wdisplay (proprietary as root), /home/user/Documents/wdisplay (as user) and in /home/user/wdisplay (as root). Permissions are set to 755. Same result in those three locations.
Location /home/jmviper/wdisplay (root proprietary, 755 permissions)
jmviper@Atlas:~/wdisplay$ ls -la
total 705948
drwxr-xr-x 2 root root 12288 feb 20 00:37 .
drwxr-xr-x 22 jmviper jmviper 4096 feb 20 00:37 …
-rwxr-xr-x 1 root root 1851968 feb 20 00:37 acurite.exe
-rwxr-xr-x 1 root root 2353592 feb 20 00:37 adddatamysql.exe
-rwxr-xr-x 1 root root 73728 feb 20 00:37 AtUsbHid.dll
-rwxr-xr-x 1 root root 19785728 feb 20 00:37 avcodec-56.dll
-rwxr-xr-x 1 root root 24354816 feb 20 00:37 avcodec-57.dll
-rwxr-xr-x 1 root root 114688 feb 20 00:37 avdevice-56.dll
-rwxr-xr-x 1 root root 345088 feb 20 00:37 avdevice-57.dll
-rwxr-xr-x 1 root root 2343936 feb 20 00:37 avfilter-5.dll
-rwxr-xr-x 1 root root 4116480 feb 20 00:37 avfilter-6.dll
-rwxr-xr-x 1 root root 5377536 feb 20 00:37 avformat-56.dll
-rwxr-xr-x 1 root root 5035008 feb 20 00:37 avformat-57.dll
-rwxr-xr-x 1 root root 426496 feb 20 00:37 avutil-54.dll
-rwxr-xr-x 1 root root 604672 feb 20 00:37 avutil-55.dll
-rwxr-xr-x 1 root root 28235 feb 20 00:37 banner.gif
-rwxr-xr-x 1 root root 15787 feb 20 00:37 clientrawdescription.txt
-rwxr-xr-x 1 root root 12478408 feb 20 00:37 clientrawrealtimeftp.exe
-rwxr-xr-x 1 root root 192576 feb 20 00:37 clientrawserver.exe
-rwxr-xr-x 1 root root 15507 feb 20 00:37 climatedata.html
-rwxr-xr-x 1 root root 10216 feb 20 00:37 climatedatayear.html
-rwxr-xr-x 1 root root 714816 feb 20 00:37 clocksync.exe
-rwxr-xr-x 1 root root 6282240 feb 20 00:37 coralib3d.dll
-rwxr-xr-x 1 root root 11719008 feb 20 00:37 cronairquality.exe
-rwxr-xr-x 1 root root 11842184 feb 20 00:37 cronanythingweather.exe
-rwxr-xr-x 1 root root 11530888 feb 20 00:37 cronawekas.exe
-rwxr-xr-x 1 root root 18389560 feb 20 00:37 cronbloomsky.exe
-rwxr-xr-x 1 root root 2943552 feb 20 00:37 croncloud.exe
-rwxr-xr-x 1 root root 696384 feb 20 00:37 croncwop.exe
-rwxr-xr-x 1 root root 11867680 feb 20 00:37 cronhttpget.exe
-rwxr-xr-x 1 root root 13707472 feb 20 00:37 cronhttpgethomeweather.exe
-rwxr-xr-x 1 root root 13289736 feb 20 00:37 cronlazersnow.exe
-rwxr-xr-x 1 root root 320064 feb 20 00:37 cronledsign.exe
-rwxr-xr-x 1 root root 2668056 feb 20 00:37 cronmetardownload.exe
-rwxr-xr-x 1 root root 2354592 feb 20 00:37 cronmysql.exe
-rwxr-xr-x 1 root root 27298264 feb 20 00:37 cronnestthermostat.exe
-rwxr-xr-x 1 root root 4400664 feb 20 00:37 cronnetatmo.exe
-rwxr-xr-x 1 root root 12318968 feb 20 00:37 cronnwsforecast.exe
-rwxr-xr-x 1 root root 2383424 feb 20 00:37 cronpakbus.exe
-rwxr-xr-x 1 root root 2385472 feb 20 00:37 cronpakbusnew.exe
-rwxr-xr-x 1 root root 11466264 feb 20 00:37 cronpushnotification.exe
-rwxr-xr-x 1 root root 13808960 feb 20 00:37 cronpws.exe
-rwxr-xr-x 1 root root 30177016 feb 20 00:37 cronrainsound.exe
-rwxr-xr-x 1 root root 14546736 feb 20 00:37 cronwdwu.exe
-rwxr-xr-x 1 root root 18099880 feb 20 00:37 cronweatherflow.exe
-rwxr-xr-x 1 root root 3382808 feb 20 00:37 cronweatherreport.exe
-rwxr-xr-x 1 root root 744000 feb 20 00:37 cronwetter.exe
-rwxr-xr-x 1 root root 2816480 feb 20 00:37 cronwindfinder.exe
-rwxr-xr-x 1 root root 949312 feb 20 00:37 cronwindguru.exe
-rwxr-xr-x 1 root root 11666856 feb 20 00:37 cronwow.exe
-rwxr-xr-x 1 root root 10614136 feb 20 00:37 cronwuwebcam.exe
-rwxr-xr-x 1 root root 2275 feb 20 00:37 customclientrawlocal.txt
-rwxr-xr-x 1 root root 1123904 feb 20 00:37 dallas1wirereader.exe
-rwxr-xr-x 1 root root 1043520 feb 20 00:37 datazipbackup.exe
-rwxr-xr-x 1 root root 854 feb 20 00:37 ddenames.txt
-rwxr-xr-x 1 root root 11281 feb 20 00:37 defaultcustomscreen.ini
-rwxr-xr-x 1 root root 434176 feb 20 00:37 EasySpeech.dll
-rwxr-xr-x 1 root root 7904 feb 20 00:37 examplehtml.txt
-rwxr-xr-x 1 root root 67952 feb 20 00:37 fetch3600.exe
-rwxr-xr-x 1 root root 81920 feb 20 00:37 FTD2XX.dll
-rwxr-xr-x 1 root root 34639 feb 20 00:37 FTD2XX.sys
-rwxr-xr-x 1 root root 15917016 feb 20 00:37 ftpupd.exe
-rwxr-xr-x 1 root root 1703936 feb 20 00:37 GdiPlus.dll
-rwxr-xr-x 1 root root 289 feb 20 00:37 GoWeather.sh
-rwxr-xr-x 1 root root 160832 feb 20 00:37 hangup.exe
-rwxr-xr-x 1 root root 427072 feb 20 00:37 hawkipdata.exe
-rwxr-xr-x 1 root root 40468648 feb 20 00:37 HB1wirereader.exe
-rwxr-xr-x 1 root root 76288 feb 20 00:37 hidapi.dll
-rwxr-xr-x 1 root root 64376 feb 20 00:37 histlog2300.exe
-rwxr-xr-x 1 root root 66464 feb 20 00:37 histlog3600.exe
-rwxr-xr-x 1 root root 3411 feb 20 00:37 homeseersetup.zip
-rwxr-xr-x 1 root root 818128 feb 20 00:37 ipworks8.dll
-rwxr-xr-x 1 root root 777392 feb 20 00:37 ipworksssh9.dll
-rwxr-xr-x 1 root root 879800 feb 20 00:37 ipworksssl8.dll
-rwxr-xr-x 1 root root 1401912 feb 20 00:37 ipworksssl9.dll
-rwxr-xr-x 1 root root 612416 feb 20 00:37 iroxdata.exe
-rwxr-xr-x 1 root root 49243 feb 20 00:37 itunes.skn
-rwxr-xr-x 1 root root 3880 feb 20 00:37 javabuttons.zip
-rwxr-xr-x 1 root root 348160 feb 20 00:37 labjackud.dll
-rwxr-xr-x 1 root root 49152 feb 20 00:37 LabJackWUSB.dll
-rwxr-xr-x 1 root root 207360 feb 20 00:37 LAME_ENC.DLL
-rwxr-xr-x 1 root root 198720 feb 20 00:37 lame.exe
-rwxr-xr-x 1 root root 40239 feb 20 00:37 LE4-BLACKC.skn
-rwxr-xr-x 1 root root 39057 feb 20 00:37 LE4-DEFAULT.skn
-rwxr-xr-x 1 root root 3750744 feb 20 00:37 libfmux.so
-rwxr-xr-x 1 root root 802201 feb 20 00:37 libmfx-0.dll
-rwxr-xr-x 1 root root 1519616 feb 20 00:37 libmySQL.dll
-rwxr-xr-x 1 root root 2488 feb 20 00:37 License.txt
-rwxr-xr-x 1 root root 13144 feb 20 00:37 lightning.wav
-rwxr-xr-x 1 root root 73728 feb 20 00:37 ljackuw.dll
-rwxr-xr-x 1 root root 26 feb 20 00:37 location.txt
-rwxr-xr-x 1 root root 15587 feb 20 00:37 logo.gif
-rwxr-xr-x 1 root root 37370 feb 20 00:37 Longhorn Style-BLUE.skn
-rwxr-xr-x 1 root root 10752 feb 20 00:37 LRTimeLog.exe
-rwxr-xr-x 1 root root 56754 feb 20 00:37 luna-BLUE.skn
-rwxr-xr-x 1 root root 43843 feb 20 00:37 luna-HOMESTEAD.skn
-rwxr-xr-x 1 root root 29207 feb 20 00:37 luna-METALLIC.skn
-rwxr-xr-x 1 root root 57613 feb 20 00:37 macos.skn
-rwxr-xr-x 1 root root 1060864 feb 20 00:37 mFC71.dll
-rwxr-xr-x 1 root root 12120632 feb 20 00:37 moviemaker.exe
-rwxr-xr-x 1 root root 168000 feb 20 00:37 mpegtoflash.exe
-rwxr-xr-x 1 root root 53820 feb 20 00:37 mxskin24.skn
-rwxr-xr-x 1 root root 58946 feb 20 00:37 mxskin28.skn
-rwxr-xr-x 1 root root 22528 feb 20 00:37 myutil.dll
-rwxr-xr-x 1 root root 11828 feb 20 00:37 mywebpagetemplate.txt
-rwxr-xr-x 1 root root 185 feb 20 00:37 newarrowdown.gif
-rwxr-xr-x 1 root root 933 feb 20 00:37 newuparrow.gif
-rwxr-xr-x 1 root root 268943 feb 20 00:37 onepagecustomtemplates.zip
-rwxr-xr-x 1 root root 78 feb 20 00:37 open2300.conf
-rwxr-xr-x 1 root root 3122 feb 20 00:37 open3600.conf
-rwxr-xr-x 1 root root 4995 feb 20 00:37 owntemplate-deutsch.txt
-rwxr-xr-x 1 root root 6682 feb 20 00:37 owntemplate.txt
-rwxr-xr-x 1 root root 5157 feb 20 00:37 pagepersonelle.txt
-rwxr-xr-x 1 root root 93760 feb 20 00:37 pager.exe
-rwxr-xr-x 1 root root 114688 feb 20 00:37 PakBusDLL.dll
-rwxr-xr-x 1 root root 27200 feb 20 00:37 PingDavis.exe
-rwxr-xr-x 1 root root 2998 feb 20 00:37 Placeholder.bmp
-rwxr-xr-x 1 root root 104960 feb 20 00:37 POWERP32.DLL
-rwxr-xr-x 1 root root 52012 feb 20 00:37 rainrecorded.wav
-rwxr-xr-x 1 root root 142285 feb 20 00:37 readmeacurite.txt
-rwxr-xr-x 1 root root 795 feb 20 00:37 readmedatabase.txt
-rwxr-xr-x 1 root root 1112 feb 20 00:37 readme.txt
-rwxr-xr-x 1 root root 12504896 feb 20 00:37 realtimeftp2.exe
-rwxr-xr-x 1 root root 1766 feb 20 00:37 Realtimesvgviewer.txt
-rwxr-xr-x 1 root root 19520 feb 20 00:37 Reboot32.exe
-rwxr-xr-x 1 root root 138304 feb 20 00:37 runningprocs.exe
-rwxr-xr-x 1 root root 8087 feb 20 00:37 samplecustomhtml-deutsch.txt
-rwxr-xr-x 1 root root 9137 feb 20 00:37 samplecustomwebpage.html
-rwxr-xr-x 1 root root 3406 feb 20 00:37 Sample Stylesheet.css
-rwxr-xr-x 1 root root 303616 feb 20 00:37 SDL.dll
-rwxr-xr-x 1 root root 1036288 feb 20 00:37 simplepb.dll
-rwxr-xr-x 1 root root 143360 feb 20 00:37 SoundTouch.dll
-rwxr-xr-x 1 root root 4405 feb 20 00:37 spanishcustomwebpage.txt
-rwxr-xr-x 1 root root 2526 feb 20 00:37 sunicon.jpg
-rwxr-xr-x 1 root root 155712 feb 20 00:37 switch12volts.exe
-rwxr-xr-x 1 root root 261120 feb 20 00:37 swresample-1.dll
-rwxr-xr-x 1 root root 289792 feb 20 00:37 swresample-2.dll
-rwxr-xr-x 1 root root 436224 feb 20 00:37 swscale-3.dll
-rwxr-xr-x 1 root root 508928 feb 20 00:37 swscale-4.dll
-rwxr-xr-x 1 root root 129214 feb 20 00:37 tagslist.txt
-rwxr-xr-x 1 root root 966656 feb 20 00:37 TAPIExCt.dll
-rwxr-xr-x 1 root root 264978 feb 20 00:37 tempdirplotnew.bmp
-rwxr-xr-x 1 root root 40644 feb 20 00:37 testtags.txt
-rwxr-xr-x 1 root root 647744 feb 20 00:37 transparentimage.exe
-rwxr-xr-x 1 root root 4055 feb 20 00:37 turboactivate.dat
-rwxr-xr-x 1 root root 987400 feb 20 00:37 turboactivate.dll
-rwxr-xr-x 1 root root 326920 feb 20 00:37 turboactivate.exe
-rwxr-xr-x 1 root root 10546 feb 20 00:37 unins000.dat
-rwxr-xr-x 1 root root 718497 feb 20 00:37 unins000.exe
-rwxr-xr-x 1 root root 486 feb 20 00:37 universal.txt
-rwxr-xr-x 1 root root 236096 feb 20 00:37 unwise.exe
-rwxr-xr-x 1 root root 45056 feb 20 00:37 USB.dll
-rwxr-xr-x 1 root root 61401 feb 20 00:37 VistaXP-VISTAXPB2.skn
-rwxr-xr-x 1 root root 397312 feb 20 00:37 WaveExCtrl.dll
-rwxr-xr-x 1 root root 3842624 feb 20 00:37 wdfacebook.exe
-rwxr-xr-x 1 root root 7348 feb 20 00:37 wdlclickhere.gif
-rwxr-xr-x 1 root root 7672 feb 20 00:37 wdlconfig.xml
-rwxr-xr-x 1 root root 544030 feb 20 00:37 wdlv6_09.swf
-rwxr-xr-x 1 root root 21835710 feb 20 00:37 wdmssql.exe
-rwxr-xr-x 1 root root 1060928 feb 20 00:37 wdmysql.exe
-rwxr-xr-x 1 root root 320000 feb 20 00:37 wdscreensaver.scr
-rwxr-xr-x 1 root root 11039744 feb 20 00:37 WDsendtetherdata.exe
-rwxr-xr-x 1 root root 2275904 feb 20 00:37 wdstartdelay.exe
-rwxr-xr-x 1 root root 4121624 feb 20 00:37 wdtwitternew.exe
-rwxr-xr-x 1 root root 4233280 feb 20 00:37 WDutubeupload.exe
-rwxr-xr-x 1 root root 3373592 feb 20 00:37 wdwarningemail.exe
-rwxr-xr-x 1 root root 4094528 feb 20 00:37 wdwatch.exe
-rwxr-xr-x 1 root root 2695744 feb 20 00:37 wdwebcamcapture.exe
-rwxr-xr-x 1 root root 14398480 feb 20 00:37 wdxmlwarning.exe
-rwxr-xr-x 1 root root 746560 feb 20 00:37 weatherbug.exe
-rwxr-xr-x 1 root root 85835760 feb 20 00:37 weatherdisplay
-rwxr-xr-x 1 root root 27709 feb 20 00:37 Weather-displaybanner.gif
-rwxr-xr-x 1 root root 67093528 feb 20 00:37 WeatherDisplay.exe
-rwxr-xr-x 1 root root 344849 feb 20 00:37 Weather_Display_Icons.zip
-rwxr-xr-x 1 root root 187446 feb 20 00:37 WeatherDisplaylogo.bmp
-rwxr-xr-x 1 root root 108451 feb 20 00:37 WMCmd.vbs
-rwxr-xr-x 1 root root 694848 feb 20 00:37 wmr100.exe
-rwxr-xr-x 1 root root 11765256 feb 20 00:37 wmr200history.exe
-rwxr-xr-x 1 root root 2652696 feb 20 00:37 wmr300decode.exe
-rwxr-xr-x 1 root root 49728 feb 20 00:37 wmr300histolder.exe
-rwxr-xr-x 1 root root 1153872 feb 20 00:37 wodSFTP.ocx
-rwxr-xr-x 1 root root 204872 feb 20 00:37 ws1080.DLL
-rwxr-xr-x 1 root root 14196392 feb 20 00:37 WUrapidfire.exe
-rwxr-xr-x 1 root root 14277 feb 20 00:37 wxbanner.gif
-rwxr-xr-x 1 root root 5831 feb 20 00:37 wxbanner.jpg
-rwxr-xr-x 1 root root 11071 feb 20 00:37 wxlocal14.html
-rwxr-xr-x 1 root root 3605 feb 20 00:37 wxlocal15.html
-rwxr-xr-x 1 root root 2458 feb 20 00:37 xmlhelp.txt
-rwxr-xr-x 1 root root 147456 feb 20 00:37 Zip32.dll
WD linux will try to create a folder and create the ini settings files in
/[home]/Documents/wdisplay/
No way… I tried in /home/Documents/wdisplay, /home/user/Documents/wdisplay… I have Debian OS in Spanish so folder Documents is Documentos but with no result.
If you want to have a look I can give you my IP and do a port forwarding to port 22 for you to login by ssh to the system. Debian is with xfce so you can easily get in with Bitvise for example
thanks anyway
I suggest you try Ubuntu 16.04 LTS. That is working fine for me with the 9th February build and WD runs happily with the default Unity desktop.
I also have a VNC server installed which uses the XFCE desktop. WD crashes if I try to change any settings under XFCE, but Brian has written a WD Client which allows remote viewing of the main screen using XFCE.
No way... I tried in /home/Documents/wdisplay,I did mean for you to run it from there you can install and run it from any where but that is where WD tries to save its data and settings files what shows in the file location.txt
That’s the clue… it contains /root/Documents/wdisplay/ and I’ve changed that path but when WD starts it changed to the default path again so I’ve created /root/Documents/wdisplay directory and it worked
Thanks for the help and I hope this will help another newbie in Linux like me
Thank you for your suggestion but it was sounding strange to me that WD was not working neither latest Ubuntu 17.10 nor Debian 9 Stretch. Finally it was a location issue with ini files.
Greetings from Spain
I had the same problem but found that if you just double clicked the ‘weatherdisplay’ icon it starts OK.
I had it running an old ws2307 that only gave me indoor and outdoor temps and humidity.
hope this helps
BTW I am running Debian 9 at the moment and have just loaded WH1080 on it and is OK …looks like it wont run as root, a good idea?
