Author Topic: Segmentation fault  (Read 1999 times)
Offline GrantK
  • Davis VP2+ with 24 Hr SPFARS
  • Bay of Islands, New Zealand
  • Win NT 10.0
  • Firefox 58.0
Re: Segmentation fault
« Reply #15 on: February 20, 2018, 12:01:32 PM »
I suggest you try Ubuntu 16.04 LTS.  That is working fine for me with the 9th February build and WD runs happily with the default Unity desktop.
I also have a VNC server installed which uses the XFCE desktop.  WD crashes if I try to change any settings under XFCE, but Brian has written a WD Client which allows remote viewing of the main screen using XFCE.
Online Weather Display
  • Davis VP2
  • New Zealand
  • Win NT 10.0
  • Chrome 64.0.3282.167
    • Weather Display
« Reply #16 on: February 20, 2018, 06:06:26 PM »
Quote
No way... I tried in /home/Documents/wdisplay,
I did mean for you to run it from there
you can install and run it from any where
but that is where WD tries to save its data and settings files
what shows in the file
location.txt
Offline jmviper
  • Murcia, SPAIN
  • (Linux Mint)
  • Chrome 64.0.3282.119
    • MeteoArchena
« Reply #17 on: February 20, 2018, 11:58:36 PM »
location.txt
That's the clue... it contains /root/Documents/wdisplay/ and I've changed that path but when WD starts it changed to the default path again so I've created /root/Documents/wdisplay directory and it worked
Thanks for the help and I hope this will help another newbie in Linux like me  :wink:
  Davis Vantage Pro2 Plus
 www.meteoarchena.es
Offline jmviper
  • Murcia, SPAIN
  • (Linux Mint)
    • MeteoArchena
« Reply #18 on: February 21, 2018, 12:20:31 AM »
Thank you for your suggestion but it was sounding strange to me that WD was not working neither latest Ubuntu 17.10 nor Debian 9 Stretch. Finally it was a location issue with ini files.
Greetings from Spain
 www.meteoarchena.es
Offline gumnut
  • Wattamondara NSW Australia
    • blatchyj
  • (Linux Mint)
  • Firefox 52.0
    • Wattamondara weather
« Reply #19 on: February 26, 2018, 12:31:48 AM »
I had the same problem but found that if you just double clicked the 'weatherdisplay' icon it starts OK.
I had it running an old ws2307 that only gave me indoor and outdoor temps and humidity.
hope this helps
Debian Stretch  AMD x64
Firefox ESR
Offline gumnut
    • blatchyj
  • (Linux Mint)
  • Firefox 52.0
« Reply #20 on: February 26, 2018, 02:14:25 AM »
BTW I am running Debian 9 at the moment and have just loaded WH1080 on it  and is OK ....looks like it wont run as root, a good idea?
Firefox ESR
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #21 on: February 26, 2018, 03:14:13 AM »
as long as the /home/Documents/wdisplay/
folder and the settings files have the right privaledges it should be OK
Offline gumnut
    • blatchyj
  • (Linux Mint)
  • Firefox 52.0
« Reply #22 on: February 26, 2018, 06:54:03 AM »
just checked and it seems OK
Firefox ESR
Offline Asemwaldwx_58-12
  • Stuttgart-Asemwald, Baden-Wuerttemberg, Germany
  • (Linux Mint)
  • Firefox 66.0
    • Asemwald@Filderstadtweather
« Reply #23 on: April 03, 2019, 06:54:54 PM »
That's what I found out today ...
Mint19.1 seems to have a problem with symlinks ... I had to restart rigel last night only to find out after work today that Weatherdisplay wasn't working anymore, because the symlink to Dokumente/wdisplay was gone.
Hans @ Asemwald
Linux Mint 19.1 / AMD FX-8350 8x4.0 GHz, 16GB DDR3 / Netatmo (Inside, Outside, Rain, Wind) / Weather Display 10.37linux301
West Coast Eagles - We're flying high!
Offline gumnut
    • blatchyj
  • (Linux Mint)
  • Firefox 60.0
« Reply #24 on: April 03, 2019, 10:00:06 PM »
Hi I am running WD on Debian 9 and had the same problem as you, for some reason it cannot be opened using sudo.
Try clicking on the weatherdisplay icon in the WD folder , It works for me
Firefox ESR
  • (Linux Mint)
  • Firefox 66.0
« Reply #25 on: April 06, 2019, 04:59:34 PM »
As soon as the symlink to "Documents/wdisplay" was gone, WD stopped working for good. I did set up Documents/wdisplay as a copy of Dokumente/wdisplay now ... that worked for me.
Hans @ Asemwald
