Each time I Save and Exit WD, the Weatherlink.com setting in Control Panel → Station Type & Settings → Data From Weatherlink.com is missing when I restart WD. I have to reenter the DID, Key, User, and Password then re-tick “Enabled” every time I restart WD. Any suggestions how to make sure the information is saved upon exiting WD?
try making sure that you also tick that its a Davis VP/Vue station as well
also though which verison/build of WD?
also are you clicking on save/close?
also are you running WD as admin?
Yes, ticking Davis Vantage Pro/Plus/6161/50/VP2/Vue
Version 10.37S62
Yes, clicking save/close
No, not running WD as admin, but I can change that.
try the latest update of WD as I might have fixed something there already
I shutdown WD, rebooted my PC, and installed Build 66. When I started WD, the Weatherlink.com info was blank again. I entered all the info, selected save/close. I shutdown WD, restarted it, and the Weatherlink.com info was saved and Enabled but the VP2 weather station was no longer ticked, but WD is receiving data. See attached screen capture of the Station Type setup.
