Problem Upload Data Service Wunderground, Pws etc...
I realized today, that since I started sending data online, that the various services such as:
Weather Underground
CWOP
PWS
They do not send data online for at least 4 days. Why?
I await your directions, thank you very much
LOG CWOP
status  0
connected to CWOP server Ok
status  0
cwop sending user DW8750 pass -1 // -1 is default (you do not have a Ham call si vers wxdisplay WD_console_16.0 10
status  0
cwop sending DW8750>APRS,TCPIP*:@071340z38.1553/15.2234_351/008g013t062r000p000P000b10082h52.WD 10
status  0
LOG PWS
PWS data to send http://www.pwsweather.com/pwsupdate/pwsupdate.php?ID=XXXXXX&PASSWORD=XXXXXXXX&dateutc=2018-02-07+13%3A45%3A00&winddir=345&windspeedmph=9.2&windgustmph=9.2&humidity=56&tempf=60.5&rainin=0.00&dailyrainin=0.000&monthlyrainin=0.319&yearlyrainin=2.236&baromin=29.772&dewptf=44.7&weather=49&clouds=DW8750>APRS,TCPIP*:@071340z38.1553/15.2234_351/008g013t062r000p000P000b10082h52&solarradiation=0&UV=0.0&softwaretype=WeatherDisplay%3AWD_console_16.0&action=updateraw
PWS data send Ok 14:48:31
LOG WEATHER UNDEGROUND
WU data to send http://weatherstation.wunderground.com/weatherstation/updateweatherstation.php?ID=ISICILIA97   //WU ID&PASSWORD=XXXXXX&dateutc=2018-02-07+13%3A45%3A00&winddir=345&windspeedmph=9&windgustmph=15&humidity=56&tempf=60.5&rainin=0.00&baromin=29.772&dewptf=44.7&weather=&clouds=&dailyrainin=0.00&softwaretype=WeatherDisplay%3AWD_console_16.0&action=updateraw
Wunderground data send Ok 14:49:45
maybe same problem you had before in what directory you are starting consolewd
No now always start from the directory if not the other files would not start, clientraw, metetemplate, which then seems to do the upload,
but apparently do not arrive on the various sites data, are lost as ever … ??
**** updating data logs
Doing CWOP
Sending CWOP data now
updating meteotemplate fast
Updating meteotemplate UTC ->1518034202
updating wunderground
Sending WU data now
updating WOW
Sending WOW data now
updating PWS
Sending pws data now
updating windfinder
meteotemplatedata to send www.ombarcellonapg.com/wdisplay/template/api.php?U=1518034202&T=13.6&TMX=13.7&TMN=13.6&TIN=20.9&HIN=0&H=51&P=1012.1&W=16.7&G=20.1&B=295&R=0.0&RR=0.000&PASS=Waptix89&SW=WD&T1=0.0&T2=0.0&T3=0.0&T4=0.0&T5=0.0&T6=0.0&T7=0.0&T8=0.0&T9=0.0&T1=0.0&H2=0&H3=0&H4=0&H5=0&H6=0&H7=0&H8=0&H9=0&TS1=0.0&TS2=0.0&TS3=0.0&TS4=0.0&SM1=0.0&SM2=0.0&SM3=0.0&SM4=0.0&LW1=0&LW2=0&LW3=0&LW4=0
wow data to send http://wow.metoffice.gov.uk/automaticreading?siteid=19124913&siteAuthenticationKey=XXXXX&dateutc=2018-02-07+20%3A10%3A02&winddir=274&windspeedmph=10&windgustmph=12&humidity=51&tempf=56.5&rainin=0.000&baromin=29.887&dewptf=38.5&weather=49&clouds=&dailyrainin=0.000&soilmoisture=0.0&leafwetness=0.0&softwaretype=WeatherDisplay
Sending windfinder data now
updating records to ini file
windfinder data to send http://www.windfinder.com/wind-cgi/httpload.pl?sender_id=barcellona_pozzo_di_gotto&password=XXXXXXXXXX&date=07.02.2018&time=21:10&airtemp=14&windspeed=7&gust=13&winddir=274&pressure=1012&rain=0
WU data to send http://weatherstation.wunderground.com/weatherstation/updateweatherstation.php?ID=ISICILIA97   //WU ID&PASSWORD=XXXXXX&dateutc=2018-02-07+20%3A10%3A00&winddir=274&windspeedmph=10&windgustmph=12&humidity=51&tempf=56.5&rainin=0.00&baromin=29.887&dewptf=38.5&weather=&clouds=&dailyrainin=0.00&softwaretype=WeatherDisplay%3AWD_console_16.0&action=updateraw
PWS data to send http://www.pwsweather.com/pwsupdate/pwsupdate.php?ID=ME1989&PASSWORD=XXXXXXXX&dateutc=2018-02-07+20%3A10%3A02&winddir=295&windspeedmph=10.3&windgustmph=11.5&humidity=51&tempf=56.5&rainin=0.00&dailyrainin=0.000&monthlyrainin=0.319&yearlyrainin=2.236&baromin=29.887&dewptf=38.5&weather=49&clouds=DW8750>APRS,TCPIP*:@072010z38.1553/15.2234_295/009g015t056r000p000P000b10121h51&solarradiation=0&UV=0.0&softwaretype=WeatherDisplay%3AWD_console_16.0&action=updateraw
status  0
status  0
*****Received count =  ----------------------------->  513
Found complete record 455
252 ** minute
the problem might be with the UTC routine
which I changed so that it would work with meteotemplate but it might have broken it for others
so I will make it so that change only is for meteotemplate
Ok I await your solution, and also I wanted to ask if I could also include Weather CLoud as a service?
try
http://www.weather-display.org/downloadfiles/consolewdtest.zip
re the utc change
It seems that on PWS the station is back online, while on weather undergound and cwop nothing yet.
what shows if you run those cron programs in a terminal window
i.e
cronwu
for wunderground
It seems that the data is sent correctly, but unfortunately does not arrive on the site weather undeground, how come?
pi@raspberrypi:~/consolewdfiles $ sudo ./cronwu
WU data to send http://weatherstation.wunderground.com/weatherstation/updateweatherstation.php?ID=ISICILIA97   //WU ID&PASSWORD=xxxxxx&dateutc=2018-02-08+20%3A54%3A00&winddir=212&windspeedmph=0&windgustmph=2&humidity=78&tempf=52.6&rainin=0.00&baromin=30.085&dewptf=46.0&weather=&clouds=&dailyrainin=0.00&softwaretype=WeatherDisplay%3AWD_console_17.0&action=updateraw
Wunderground data send Ok 22:00:00
check how you have set the password etc in the config
and how that is stored in the consolewd.ini
something looks corrupted if that is what the output is saying
This is the weather undeground configuration on the config.txt file
Station name=Barcellona Pozzo di Gotto
Do wunderground=Y //For updating wunderground.com (set to Y for yes, N for no) (every 5 minutes)
Wunderground username=ISICILIA97   //WU ID
Wunderground password=XXXXXX
Wunderground timezone=+1    // e.g 12 for 12 hours ahead of GMT, -12 for - 12 hours
timezone=	(to change the local PC hour used)
In the wdconsole.ini file, there is no line covering weather undeground.
what shows in the file
cronwudata.txt
Here is the cronwudata.txt file
http://weatherstation.wunderground.com/weatherstation/updateweatherstation.php?ID=ISICILIA97   //WU ID&PASSWORD=XXXXXX&dateutc=2018-02-09+07%3A30%3A00&winddir=210&windspeedmph=3&windgustmph=5&humidity=82&tempf=50.2&rainin=0.00&baromin=30.017&dewptf=44.9&weather=&clouds=&dailyrainin=0.00&softwaretype=WeatherDisplay%3AWD_console_17.0&action=updateraw
this is the problem
//WU ID
which is in the config.txt remove that from there:
Ok I’m trying after removing that part indicated by you.
After having made the change and started the console, the usual program seems to send the data, but alas’ are not sent, I tried launching cronwu and in this way the data arrive.
you should see the output from consolewd sending it auto show in the terminal window of consolewd
if a manual send updates your WU then that indead was the problem, that line in the config.txt
and you should be OK now
This is the one that sends the consolewd file to the terminal automatically, but on the weather undeground site it does not update, while if I manually start the filme cronwu update as never?
WU data to send http://weatherstation.wunderground.com/weatherstation/updateweatherstation.php?ID=ISICILIA97&PASSWORD=XXXXXX&dateutc=2018-02-09+17%3A48%3A00&winddir=254&windspeedmph=2&windgustmph=4&humidity=78&tempf=53.5&rainin=0.00&baromin=29.834&dewptf=46.8&weather=&clouds=&dailyrainin=0.00&softwaretype=WeatherDisplay%3AWD_console_17.0&action=updateraw
all I can tell you is to keep an eye on it (the auto update)
and see if it does update WU
(and see if the data being sent changes, etc)
However I will continue to monitor it to see how it goes if it updates or not,
while on cwop and pws it does not update, only on pws updates every hour … is it normal?
