Author Topic: Problem Upload Data Service Wunderground, Pws etc...  (Read 3528 times)
Offline Cavaliere89
  • Win NT 10.0
  • Firefox 58.0
« on: February 07, 2018, 01:42:23 PM »
I realized today, that since I started sending data online, that the various services such as:
Weather Underground
CWOP
PWS
They do not send data online for at least 4 days. Why?
I await your directions, thank you very much
Code: [Select]
LOG CWOP
status  0
connected to CWOP server Ok
status  0
cwop sending user DW8750 pass -1 // -1 is default (you do not have a Ham call si vers wxdisplay WD_console_16.0 10
status  0
cwop sending DW8750>APRS,TCPIP*:@071340z38.1553/15.2234_351/008g013t062r000p000P000b10082h52.WD 10
status  0
Code: [Select]
LOG PWS
PWS data to send http://www.pwsweather.com/pwsupdate/pwsupdate.php?ID=XXXXXX&PASSWORD=XXXXXXXX&dateutc=2018-02-07+13%3A45%3A00&winddir=345&windspeedmph=9.2&windgustmph=9.2&humidity=56&tempf=60.5&rainin=0.00&dailyrainin=0.000&monthlyrainin=0.319&yearlyrainin=2.236&baromin=29.772&dewptf=44.7&weather=49&clouds=DW8750>APRS,TCPIP*:@071340z38.1553/15.2234_351/008g013t062r000p000P000b10082h52&solarradiation=0&UV=0.0&softwaretype=WeatherDisplay%3AWD_console_16.0&action=updateraw
PWS data send Ok 14:48:31
Code: [Select]
LOG WEATHER UNDEGROUND
WU data to send http://weatherstation.wunderground.com/weatherstation/updateweatherstation.php?ID=ISICILIA97   //WU ID&PASSWORD=XXXXXX&dateutc=2018-02-07+13%3A45%3A00&winddir=345&windspeedmph=9&windgustmph=15&humidity=56&tempf=60.5&rainin=0.00&baromin=29.772&dewptf=44.7&weather=&clouds=&dailyrainin=0.00&softwaretype=WeatherDisplay%3AWD_console_16.0&action=updateraw
Wunderground data send Ok 14:49:45
« Last Edit: February 07, 2018, 01:50:17 PM by Cavaliere89 »
  • Davis VP2
  • New Zealand
  • Win NT 10.0
  • Chrome 64.0.3282.140
    • Weather Display
Re: Problem Upload Data Service Wunderground, Pws etc...
« Reply #1 on: February 07, 2018, 05:16:14 PM »
maybe same problem you had before in what directory you are starting consolewd
Offline Cavaliere89
  • Win NT 10.0
  • Firefox 58.0
« Reply #2 on: February 07, 2018, 08:09:11 PM »
No now always start from the directory if not the other files would not start, clientraw, metetemplate, which then seems to do the upload,
but apparently do not arrive on the various sites data, are lost as ever .. ??
Code: [Select]
**** updating data logs
Doing CWOP
Sending CWOP data now
updating meteotemplate fast
Updating meteotemplate UTC ->1518034202
updating wunderground
Sending WU data now
updating WOW
Sending WOW data now
updating PWS
Sending pws data now
updating windfinder
meteotemplatedata to send www.ombarcellonapg.com/wdisplay/template/api.php?U=1518034202&T=13.6&TMX=13.7&TMN=13.6&TIN=20.9&HIN=0&H=51&P=1012.1&W=16.7&G=20.1&B=295&R=0.0&RR=0.000&PASS=Waptix89&SW=WD&T1=0.0&T2=0.0&T3=0.0&T4=0.0&T5=0.0&T6=0.0&T7=0.0&T8=0.0&T9=0.0&T1=0.0&H2=0&H3=0&H4=0&H5=0&H6=0&H7=0&H8=0&H9=0&TS1=0.0&TS2=0.0&TS3=0.0&TS4=0.0&SM1=0.0&SM2=0.0&SM3=0.0&SM4=0.0&LW1=0&LW2=0&LW3=0&LW4=0
wow data to send http://wow.metoffice.gov.uk/automaticreading?siteid=19124913&siteAuthenticationKey=XXXXX&dateutc=2018-02-07+20%3A10%3A02&winddir=274&windspeedmph=10&windgustmph=12&humidity=51&tempf=56.5&rainin=0.000&baromin=29.887&dewptf=38.5&weather=49&clouds=&dailyrainin=0.000&soilmoisture=0.0&leafwetness=0.0&softwaretype=WeatherDisplay
Sending windfinder data now
updating records to ini file
windfinder data to send http://www.windfinder.com/wind-cgi/httpload.pl?sender_id=barcellona_pozzo_di_gotto&password=XXXXXXXXXX&date=07.02.2018&time=21:10&airtemp=14&windspeed=7&gust=13&winddir=274&pressure=1012&rain=0
WU data to send http://weatherstation.wunderground.com/weatherstation/updateweatherstation.php?ID=ISICILIA97   //WU ID&PASSWORD=XXXXXX&dateutc=2018-02-07+20%3A10%3A00&winddir=274&windspeedmph=10&windgustmph=12&humidity=51&tempf=56.5&rainin=0.00&baromin=29.887&dewptf=38.5&weather=&clouds=&dailyrainin=0.00&softwaretype=WeatherDisplay%3AWD_console_16.0&action=updateraw
PWS data to send http://www.pwsweather.com/pwsupdate/pwsupdate.php?ID=ME1989&PASSWORD=XXXXXXXX&dateutc=2018-02-07+20%3A10%3A02&winddir=295&windspeedmph=10.3&windgustmph=11.5&humidity=51&tempf=56.5&rainin=0.00&dailyrainin=0.000&monthlyrainin=0.319&yearlyrainin=2.236&baromin=29.887&dewptf=38.5&weather=49&clouds=DW8750>APRS,TCPIP*:@072010z38.1553/15.2234_295/009g015t056r000p000P000b10121h51&solarradiation=0&UV=0.0&softwaretype=WeatherDisplay%3AWD_console_16.0&action=updateraw
status  0
status  0
*****Received count =  ----------------------------->  513
Found complete record 455
252 ** minute
« Last Edit: February 07, 2018, 08:12:38 PM by Cavaliere89 »
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #3 on: February 07, 2018, 08:21:03 PM »
the problem might be with the UTC routine
which I changed so that it would work with meteotemplate but it might have broken it for others
so I will make it so that change only is for meteotemplate
Offline Cavaliere89
  • Win NT 10.0
  • Firefox 58.0
« Reply #4 on: February 07, 2018, 10:06:57 PM »
Ok I await your solution, and also I wanted to ask if I could also include Weather CLoud as a service?
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
Offline Cavaliere89
  • Win NT 10.0
  • Firefox 58.0
« Reply #6 on: February 08, 2018, 09:10:25 AM »
try
http://www.weather-display.org/downloadfiles/consolewdtest.zip
re the utc change
It seems that on PWS the station is back online, while on weather undergound and cwop nothing yet.
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #7 on: February 08, 2018, 05:51:02 PM »
what shows if you run those cron programs in a terminal window
i.e
cronwu
for wunderground
Offline Cavaliere89
  • Win NT 10.0
  • Firefox 58.0
« Reply #8 on: February 08, 2018, 09:01:43 PM »
i.e
cronwu
for wunderground
It seems that the data is sent correctly, but unfortunately does not arrive on the site weather undeground, how come?
Code: [Select]
pi@raspberrypi:~/consolewdfiles $ sudo ./cronwu
WU data to send http://weatherstation.wunderground.com/weatherstation/updateweatherstation.php?ID=ISICILIA97   //WU ID&PASSWORD=xxxxxx&dateutc=2018-02-08+20%3A54%3A00&winddir=212&windspeedmph=0&windgustmph=2&humidity=78&tempf=52.6&rainin=0.00&baromin=30.085&dewptf=46.0&weather=&clouds=&dailyrainin=0.00&softwaretype=WeatherDisplay%3AWD_console_17.0&action=updateraw
Wunderground data send Ok 22:00:00
« Last Edit: February 08, 2018, 11:06:19 PM by Cavaliere89 »
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #9 on: February 08, 2018, 10:34:08 PM »
check how you have set the password etc in the config
and how that is stored in the consolewd.ini
something looks corrupted if that is what the output is saying
Offline Cavaliere89
  • Win NT 10.0
  • Firefox 58.0
« Reply #10 on: February 08, 2018, 11:11:40 PM »
This is the weather undeground configuration on the config.txt file
Code: [Select]
Station name=Barcellona Pozzo di Gotto
Do wunderground=Y //For updating wunderground.com (set to Y for yes, N for no) (every 5 minutes)
Wunderground username=ISICILIA97   //WU ID
Wunderground password=XXXXXX
Wunderground timezone=+1    // e.g 12 for 12 hours ahead of GMT, -12 for - 12 hours
timezone= (to change the local PC hour used)
In the wdconsole.ini file, there is no line covering weather undeground.
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #11 on: February 08, 2018, 11:15:14 PM »
what shows in the file
cronwudata.txt
Offline Cavaliere89
  • Win NT 10.0
  • Firefox 58.0
« Reply #12 on: February 09, 2018, 07:32:09 AM »
cronwudata.txt
Here is the cronwudata.txt file
Code: [Select]
http://weatherstation.wunderground.com/weatherstation/updateweatherstation.php?ID=ISICILIA97   //WU ID&PASSWORD=XXXXXX&dateutc=2018-02-09+07%3A30%3A00&winddir=210&windspeedmph=3&windgustmph=5&humidity=82&tempf=50.2&rainin=0.00&baromin=30.017&dewptf=44.9&weather=&clouds=&dailyrainin=0.00&softwaretype=WeatherDisplay%3AWD_console_17.0&action=updateraw
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #13 on: February 09, 2018, 09:07:14 AM »
this is the problem
Quote
   //WU ID
which is in the config.txt
remove that from there:
Offline Cavaliere89
  • Win NT 10.0
  • Firefox 58.0
« Reply #14 on: February 09, 2018, 04:21:27 PM »
this is the problemwhich is in the config.txt
Ok I'm trying after removing that part indicated by you.
