Ok but unfortunately today, I’ll have to put it manually because it’s not raining anymore
Ok I try and see just raining if it marks the rain or not.
The rain fell today I put it manually now.
Hello Brian, finally he reads the rain, he does not lose a shot anymore, but I saw that he does not communicate the rain rate and 'normal?
communicate rain rate where ? and not sure what you mean by normal?
I want to say that the clientraw.txt file that is generated by consolewd, does not communicate the rain rate of rain and consequently then on my site that also processes the data of the rain rate, while it rains the rain rate is 0 why?
I will look into the rain rate in the clientraw.txt for consolewd as spare time permits
Ok very kind, so then as soon as you give me the file, we’ll see when it rains if it also inserts the RAIN RATE. Thanks again
Ok thank you so much I try and tell you if he communicates the rainrate in the clientraw file.
I wanted to tell you that I’m trying the new file you sent me to read the RAIN RATE, but unfortunately it still does not read it.
I am surprised by that, it should be working (note you will need more than 1 tip of the rain gauge)
Hi Brian, I confirm that it is raining right now and the program does not communicate the data of MM / H, ie how much rain accumulates in 1 hour.
Guys today I was looking at if the program consolewd went well and looking at the console where the data received from the program flow me out these rain data and 'normal?
Considering that today it has not rained.
Current data 17:46:51: Temperature = 13.8 Windspeed = 0.0 Gustspeed = 0.0 Direction = 0 Humidity = 73 Barometer = 1015.5 Daily Rain = 0.0
***** Received count = -----------------------------> 78
Found !!
raw baro 1015.5
Short data length 4 4 4 13
rain = 174.8
new rain = 174.8
old rain = 174.8
Date OK
Found !!
@Weather Display
You could help me with the settings of rain, today it rained 4.8mm and I had to put them manually, because the program has seen only 0.2mm, until last week everything worked, since yesterday I realized how I put you above in the code that in the rain settings something is not correct, what happened? Can we solve?
I look forward to your kind help, thank you very much
what I need to see is the rain debug info when a new rain tip has occured
How can I show you?
How come it brings 175mm rain today and also old rain 175mm, yesterday it did not rain and today only 4.8mm
Current data 21:03:30: Temperature= 12.0 Windspeed =8.1 Gustspeed =9.1 Direction =320 Humidity=92 Barometer=1011.9 Daily Rain=4.8
*****Received count = -----------------------------> 59
Found !!
raw baro 1011.9
Short data length 4 4 6 0
rain =175.0
new rain =175.0
old rain =175.0
Data OK
Yesterday I had to give this command on the terminal for another application:
sudo apt-get update
Is it possible that caused the problem?
old rain is the previous rain total prior to the latest
what I need to see is when that increases (i,e when you get a new rain tip)
Ok, as soon as it rains and take the rain gauge, I tell you what value the program is processing.
I’m back home now, today it rained and the station console scores 3.30mm, the program has only processed 0.1mm.
How can I see when the millimeter has snapped on the console coming back?
