Author Topic: Problem Rain Peet Bros Ultimeter 2100  (Read 4691 times)
  • Davis VP2
  • New Zealand
  • Win NT 10.0
  • Chrome 64.0.3282.140
    • Weather Display
Re: Problem Rain Peet Bros Ultimeter 2100
« Reply #15 on: February 10, 2018, 09:15:19 PM »
I will look into the rain rate in the clientraw.txt for consolewd as spare time permits
Offline Cavaliere89
  • Win NT 10.0
  • Firefox 58.0
« Reply #16 on: February 10, 2018, 09:24:57 PM »
Ok very kind, so then as soon as you give me the file, we'll see when it rains if it also inserts the RAIN RATE. Thanks again
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #17 on: February 11, 2018, 09:04:32 AM »
Offline Cavaliere89
  • Win NT 10.0
  • Firefox 58.0
« Reply #18 on: February 12, 2018, 01:08:11 PM »
re rain rate
try update
http://www.weather-display.com/downloadfiles/consolewdtest.zip
Ok thank you so much I try and tell you if he communicates the rainrate in the clientraw file.
Offline Cavaliere89
  • Win NT 10.0
  • Firefox 58.0
« Reply #19 on: February 13, 2018, 08:26:44 AM »
I wanted to tell you that I'm trying the new file you sent me to read the RAIN RATE, but unfortunately it still does not read it.
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #20 on: February 13, 2018, 06:57:38 PM »
I am surprised by that, it should be working (note you will need more than 1 tip of the rain gauge)
Offline Cavaliere89
  • Win NT 10.0
  • Firefox 58.0
« Reply #21 on: February 14, 2018, 01:14:49 PM »
Hi Brian, I confirm that it is raining right now and the program does not communicate the data of MM / H, ie how much rain accumulates in 1 hour.
Offline Cavaliere89
  • Win NT 10.0
  • Firefox 58.0
« Reply #22 on: February 18, 2018, 04:48:48 PM »
Guys today I was looking at if the program consolewd went well and looking at the console where the data received from the program flow me out these rain data and 'normal?
Considering that today it has not rained.
Code: [Select]
Current data 17:46:51: Temperature = 13.8 Windspeed = 0.0 Gustspeed = 0.0 Direction = 0 Humidity = 73 Barometer = 1015.5 Daily Rain = 0.0
***** Received count = -----------------------------> 78
Found !!
raw baro 1015.5
Short data length 4 4 4 13
rain = 174.8
new rain = 174.8
old rain = 174.8
Date OK
Found !!
« Last Edit: February 18, 2018, 07:43:14 PM by Cavaliere89 »
Offline Cavaliere89
  • Win NT 10.0
  • Firefox 58.0
« Reply #23 on: February 19, 2018, 07:29:17 PM »
@Weather Display
You could help me with the settings of rain, today it rained 4.8mm and I had to put them manually, because the program has seen only 0.2mm, until last week everything worked, since yesterday I realized how I put you above in the code that in the rain settings something is not correct, what happened? Can we solve?
I look forward to your kind help, thank you very much
  • Davis VP2
  • New Zealand
  • Win NT 10.0
  • Chrome 64.0.3282.167
    • Weather Display
« Reply #24 on: February 19, 2018, 08:17:40 PM »
what I need to see is the rain debug info when a new rain tip has occured
Offline Cavaliere89
  • Win NT 10.0
  • Firefox 58.0
« Reply #25 on: February 19, 2018, 08:21:49 PM »
How can I show you?
How come it brings 175mm rain today and also old rain 175mm, yesterday it did not rain and today only 4.8mm
Code: [Select]
Current data 21:03:30: Temperature= 12.0 Windspeed =8.1 Gustspeed =9.1 Direction =320 Humidity=92 Barometer=1011.9 Daily Rain=4.8
*****Received count =  ----------------------------->  59
Found !!
raw baro 1011.9
Short data length 4 4 6 0
rain =175.0
new rain =175.0
old rain =175.0
Data OK
Yesterday I had to give this command on the terminal for another application:
sudo apt-get update
Is it possible that caused the problem?
« Last Edit: February 19, 2018, 08:37:13 PM by Cavaliere89 »
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #26 on: February 19, 2018, 09:36:44 PM »
old rain is the previous rain total prior to the latest
what I need to see is when that increases (i,e when you get a new rain tip)
Offline Cavaliere89
  • Win NT 10.0
  • Firefox 58.0
« Reply #27 on: February 19, 2018, 11:25:50 PM »
Ok, as soon as it rains and take the rain gauge, I tell you what value the program is processing.
Offline Cavaliere89
  • Win NT 10.0
  • Firefox 58.0
« Reply #28 on: February 20, 2018, 08:22:49 PM »
I'm back home now, today it rained and the station console scores 3.30mm, the program has only processed 0.1mm.
How can I see when the millimeter has snapped on the console coming back?
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #29 on: February 20, 2018, 08:55:04 PM »
I need to see the raw rain debug info from the console when the rain total increased
