WS 2310 worked fine for 2 years now wind speed stuck at 110.4 mph, tried switching pc on and off, nothing. Weather station on wall reading fine, nothing been touched …HELP !
which verison/build of WD?
try restarting WD
Version, 10.37s65 which I just updated to, when you reset the wind climbs up to 500+ mph, then settles down to 110.4, I have shut it down, rebooted the pc several times and updated and no change.
exit and saved, restart up to 476.5mph, in stages then back to 110.4mph station reading 0 ( flat calm here)
this sounds more like there is a problem with the data being sent from the console
i.e a hardware glitch
you could try setting a lower windspeed limit in WD so that it ignores this bad data (control panel , offsets…limits)
altered limits back and forward and its started working again, not a clue what I did !
How do I clear the data of 500mph winds …cheers !
you can reset daily max under action, reset daily …
and also you can reset/enter correct all time records there
and you can edit those values in the logfile for this month and then convert the logfile to data file
Its back again 110.4 mph
I suspect you have some hardware issue
you can set a upper windspeed limit in WD
in control panel, offsets and initial rain…limits
try setting that lower
then restart WD
