CWOP Freeze
My cwop has stopped updating for sometime which I just noticed. When I go to control panel and click the cwop icon it will freeze WD so all you get is that annoying tone when clicking anywhere on the WD screen.
I have to go to task manager to get it shut down and re-started. This happens every time I try it. Adding that I am running 10.37S64
John
most likely the cwop setup screen is loading off screen
you will need to reset the last screen settings for that
i.e the
[Main cwop setup]
setting
in the wdisplay.ini file
(edit that when WD is not running)
That was it, had a value of over 2000
Thank You
John
John,
I had the same issue, and problem was same. CWOP setup panel was loading off screen. However, I haven’t been able to determine why it quit updating. My Weather Underground page has been updating fine, but I just got back from a long trip, and CWOP quit updating 15 days ago.
Did you determine why your CWOP was not updating?
Jim
see what shows in the CWOPlogsend.txt file
It appears to time out:
CWOP data send start 07:20:00 3/5/2018
APRS Connecting to: rotate.aprs.net
Aprs connected
sending pass command
user WE1A pass **** vers wx-display 10.37S67
Time out
Jim
try changing the default server you are set to connect to
e. g
to cwop.aprs.net
in the cwop setup, server setup
I tried multiple servers and ports. All give me the ‘timeout’.
I found a list of servers on the CWOP site, and tried them using a program I found called tcping.exe that allows me to see if the server responds and if the ports are open. Not all of the servers responded to the ping, but four did. So I tried those four. Always got a time out. I read there was a server migration recently, so I wonder if my account was dropped during the migration.
I left CWOP a message, but an email to Russ Chadwick’s domain email at wxqa.com bounced (hope he’s okay). I don’t have a response yet.
Hello, days ago my CWOP leaves flat on the page
http://www.meteotorrelavega.com/weather28/index.php?p=wsPartners&s=cwop&lang=en#data-area
use WD 10.37s53
CWOP data send start 10:36:04 03/20/2018
APRS Connecting to: cwop.aprs.net
Aprs connected
user DW5826 pass -1 vers wx-display 10.37S53
Sending the aprs data now
APRS data send:
DW5826> APRS, TCPIP *: @ 100746z4320.87N / 00403.23W_256
/000g002t067r000p004P000b10180h97.WD 233
Disconnecting from the aprs server now
Finished
What can be
emilio
Solved
solved in what way, i.e what did you change
Hello, removing the wdisplay.ini and start to create another one
