On 27/01/18 @ 15.34 WD threw a wobbly (first time) and stopped doing anything
The console continued as normal (still has YTD) and so I extracted the Davis logger data whereupon there is no rainfall in YTD with in WD. When I inspected the datafile -at the time (dailylog) - it had all the data but the rain data was not populated from that time onwards.
Also when I look at the detailed rain chart information (click table / rain to date / detailed rain data) there appears to be nothing in previous years but 2018 both daily and ytd are populated.
I think some form of rebuilt is required but am not sure how to do this.
Can anyone advise please.
Also I noted that at the time WD reset temperature rain etc to F, inches etc which I changed back to european.
see if you have a back up wdisplay.ini settiings file
e.g in the
databackup12018.zip file in the databackup folder
copy/extract that to the WD location to replace the existing wdispla.ini file (when WD is not running)
For some reason the front rain data (bottom left main screen) is now showing rain in inches, despite always being in mm. My VP2 was set up n mm and is still showing millimetres.
Hi, that missing temperature reading that has happened to me as well 2/3 times now, but not for about 4 weeks now about the time I installed build s62. But I have just reread your post & you are on s64, so not much help there.
I have reset inches to mm but the data is not reading correct.
As soon as I changed it all rain data displayed changed to the same figures across the table
There should be differences in YTD / daily - see picture wd main page
The data is in the txt file but it is not reading it correctly.
you can set the needed rain totals under control panel, offsets and initial rain
or you can set to use the console rain totals
in the davis setup in the weather station type setup
if you mean under view, rain charts
then that data comes from the wdisplay.ini settings file
in the
[Rain Chart]
section
see if you have a back up of that file and use that part from the back up or similar (exit WD when you make those changes)
