Hi.
I have an WMR89.
The problem is when the temperature is coming down below zero.
WD is not reading the minus C. It stops on the last positive temperature.
The temperature in the WMR89 display is the correct value.
What can be the problem?
Hi.
I have an WMR89.
ah
you will be the first person to be using the new WMR89 support
I need to put my sensor into the freezer and see what happens in the raw data and accomadate that
I will do that over the coming days and get back to you for a fix
HI
I have fixed this
update your version of WD to the latest version update (i.e download again (your settings will not be lost)
Thanks for an fast update.
It is working fine now
